Ready to shoot it-CRANKS BUT WON'T START
  • 1 Post By Antiquerod
Old 03 Dec 2015, 08:19 am
Angry Ready to shoot it-CRANKS BUT WON'T START
I'm at wits end. 2003 2.4 non turbo. Sitting about 3 months after a fan wiring fire. Only damaged fan wiring connecter and wires to fog lamps. Minimal and wires repaired. No Codes after key dance. Has spark, fuel under pressure at the fuel rail. Timing belt in good shape. Fuses good, changed ASD relay. Upon initial crank acts like want s to start then nothing. Let sit for a few minutes again same attempts to start then nothing just cranks with no attempt to start. I always thought if you have spark and fuel it should run. Any suggestions where to go next?
Old 03 Dec 2015, 08:27 am
Default Re: Ready to shoot it-CRANKS BUT WON'T START
You also have to have compression and air. Try removing the air intake hose and shooting about a 2 second shot of starting fluid in it. See if it starts and runs then. If so, then you need to do some more research. If not, take a look at the wiring to the crank position sensor and the cam position sensor. Try that and get back to us. You state you have fuel and spark, but that won't make it start if it's missing a signal.
Hey, hey I wanna be a rock star.
Old 03 Dec 2015, 08:34 am
Tried Starting fluid no change at all. I did replace the cam sensor it was the easiest and first thought since that is where the heat was from the wire fire.
Old 03 Dec 2015, 08:46 am
instigator here! if you decide to shoot it, i will reimburse you $10 towards the ammunition via paypal upon you posting a picture.
i would verify spark from each plug, do a compression test, and verify that the injectors are pulsing as they should.
Old 03 Dec 2015, 08:48 am
LionPT's Avatar
What about the sensor plug, was that damaged...was it replaced.
By chance did you also remove the coil plug..?? Users in the past have gotten the coil & cam sensor plug mixed up when plugging them back in.
Old 03 Dec 2015, 11:12 am
Thanks for all the input. I think I'm going to wait on wasting the ammo. Tomorrow I am going to verify the fuel pump pressure and borrowing a noid to check the injectors. The sensor plug actually was not damaged. It was the connector for the electric fan.
I did read in the forum you could have spark on some and not other cylinders so one more check to make.
I'll give an update after I complete the next round of troubleshooting.
Old 03 Dec 2015, 11:39 am
I would suggest if you have good engine timing and fuel pressure to remove the camshaft sensor wire and try starting it with the camshaft sensor wire disconnected. The fire from the fan connector might have effected the camshaft wiring. Do not keep cranking it if it does not start right away after removing the camshaft sensor connector. The Chrysler sensors run on hall effect sensors. If the engine timing is good the PT Cruiser will start with cam sensor connector disconnected. You might have a short in the camshaft wiring going to the PCM, the PCM might have an internal short causing the camshaft sensor not to work properly, or something is effecting the camshaft signal.
I would also check any wiring in the area where the fire from the radiator fan wiring can reach or overheat.
Old 13 Dec 2015, 11:28 am
Smile Re: Ready to shoot it-CRANKS BUT WON'T START
Thanks for all the advice. After several more attempts to start, it finally fired up.The issue seemed to be old gas. Learned it had been sitting for about 6 months after the wiring fire. When it started it smoked white smoke like a steam locomotive but cleared up after about 10 minutes of running and has run like a top every since. A great supporting site here for Cruiser owners.
rckstein likes this.
Old 13 Dec 2015, 01:37 pm
On a previous post you mentioned:
I would think if it was old gas the starting fluid would have started the engine. I would double check any wiring and contacts that is involved with the engine timing while the engine is running to make this problem doesn't come back. It's easier to trouble shoot when its running.
Old 13 Dec 2015, 11:07 pm
Congratulations. Now go drive it like you stole it for a couple of days.
Cranks but no start? C300392 Tech & Performance Forum 4 15 Apr 2016 07:58 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
I'm ready to shoot my 01 PT!@! Shieldwolf Tech & Performance Forum 13 14 Jun 2012 09:45 pm
