Aluminum shards in Trans Pan
Like Tree16Likes
Old 11 Dec 2015, 12:09 pm
Default Aluminum shards in Trans Pan
Good day all,
I've often visited this site and have always found great topics.
Car will not shift out of first gear. I was trying to do all I could before taking it to get major work done. I can't figure out where these curved aluminum shards, about 6 of them and the longest being about 3 inches, came from. They are about 1/4 inch thick. I found them lying in my tranny pan as I was changing the oil and filter.
Took the pieces in a sandwich bag to a transmission guy that my bro-in-law knows and he said it could have came from the drum inside.
Anyone ever run into this? I'll be asking at the dealer later today after work.
Thanks.
"Whether you think you can, or you think you can't-- you are right." -Henry Ford
2007 PT Cruiser Limited, 2.4L Turbo 75,000M
Old 11 Dec 2015, 01:41 pm
Handy_Cruiser's Avatar
Default Re: Aluminum shards in Trans Pan
Are there really aluminum, or are they steel? You might take a magnet and see.
The reason I say that is that one of the more common failures of these transmissions is to shear the teeth out of the sun gear. And I think some folks call the sun gear a drum. It happens when you have weak pressure and are shifting from third to fourth if I remember right. After that, the transmission still pulls but it will be stuck in limp mode and will not shift.
I used to have one in a bucket of left over tranny parts. But I don't any more. Just put 41TE sun gear in Google images and you can see some photos.
Old 11 Dec 2015, 02:14 pm
It is aluminum, the magnet in the pan wouldn't pick them up. I tried. I failed to mention it is automatic. And I at first thought they looked like spline teeth but I didn't think a gearshaft would be made with aluminum teeth. But that's just me assuming.
I'll check that out though, thanks a lot.
When this initially happened I changed out the output speed sensor thinking that might be it. I had to order the input speed sensor and wait for it to arrive. As I changed the output sensor I also removed the input one and checked it and found it dirty. I cleaned it and reinstalled it. It ran fine after that for two days then it happened again and that's why I dove deeper into it.
Old 11 Dec 2015, 02:25 pm
Anything beyond fine flakes is time to tear down the transmission. But I am sure your transmission shop already advised this.
Most better or Performance transmission shops shop consider the A604/41TE a basket case transmission.
The most common failure is the Torque converter on these.
Old 11 Dec 2015, 02:43 pm
Are you getting any transmission trouble codes?
Old 11 Dec 2015, 03:35 pm
Yes. P0700, which when I asked was told it's a general reference to the transmission. Nothing particularly specific.
Old 11 Dec 2015, 03:38 pm
a better scanner (i'm spoiled) will give you specific codes, not just the 0700. see here:
either way... you have big chunks of metal and a trans guy telling you what likely broke. IMO you should be focusing on teardown + getting parts or a replacement instead of looking for hopes and dreams that it'll be a simple or cheap fix.
Old 11 Dec 2015, 03:55 pm
Yea, I am. I've past the state of denial, haha! I will see the dealer today and get a quote. Nice scanner, by the way. I stay away from all Snap-On trucks because I never walk out with just the tool I was looking for. It's a toy store for big kids.
Old 11 Dec 2015, 03:57 pm
Oh, and I will share with you guys what I learn.
Thanks a lot all.
Old 11 Dec 2015, 04:22 pm
Yea, I am. I've past the state of denial, haha! .
i can relate. i've blown up every automatic i've ever owned. i drive only stick now and i've found when they show signs of breaking, they're generally still fixable.
Tags
first gear, transmission, transmission fluid, transmission pan, transmission problems
Replaceing PT cruiser Trans- Prepping trans questions Wiredright Tech & Performance Forum 6 13 Feb 2013 10:59 am
Aluminum intake lowpt General PT Cruiser Discussions 3 26 Sep 2011 03:35 pm
ALUMINUM TRANSMISSION PAN ??? lmmegt Vendors & Buyers Forum 1 23 Sep 2009 07:29 am
Aluminum Repair pt4cec General PT Cruiser Discussions 2 25 Jun 2009 07:36 am
Aluminum Chromate Jeff V General PT Cruiser Discussions 5 27 Jul 2003 05:57 pm
