Turbo hoses
Old 04 Jan 2016, 05:59 pm
Default Turbo hoses
Hi can anyone help I have a 2005 turbo the hoses are not correct, the hose from the Pcv valve is going direct to the air intake box and the hose from the brake booster going to where the Pcv hose should go. Also the hose from the turbo is going to the rocker valve cover. I now this is not correct can anyone advise on where they should all go
Old 04 Jan 2016, 06:17 pm
SPLNeon's Avatar
Default Re: Turbo hoses
Vacuum line setups - Dodge SRT Forum
This will get you started.
THE UNDISPUTED KING OF THE PARKING LOT
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.95 at 118.41mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 05 Jan 2016, 09:33 pm
Thanks for your quick reply do you know if the brake booster can be feed from the turbo. As there is only one outlet on the intake which is for the Pcv valve
Old 06 Jan 2016, 05:51 am
SPLNeon's Avatar
I have two vacuum source ports on my upper intake, and one on the throttle body. Check to see if one is broke off?!
96 SOHC Neon Turbo
Old 06 Jan 2016, 11:53 am
Thanks while iam checking quick question the larger hose coming from the turbo where does it go to mine is going direct to the air intake box
Old 06 Jan 2016, 12:15 pm
image.jpg. Have taken pic of the two outlets one going to brake booster the other a four way connecter block
Old 06 Jan 2016, 12:56 pm
Hi have been looking at some pics of other pt iam sure that the Pcv valve hose is to go to the intake and also the brake booster hose to the intake manifold the four way connecter to the turbo ? My car runs ok but it uses a lot of oil ( no smoke ) and sometimes you get a smell of oil hoping that rerouting the hoses correctly will solve this
Old 06 Jan 2016, 04:58 pm
SPLNeon's Avatar
I don't have the stock airbox or intake tubing anymore and have deleted a lot of the vacuum lines, so I wouldn't be the one to answer those questions. Someone else will have to supply a pic of their stock set up.
96 SOHC Neon Turbo
vacuum hoses on 07 non turbo broncof1 Tech & Performance Forum 2 20 Aug 2011 02:43 pm
Heater Hoses NavyCruiser Tech & Performance Forum 3 22 May 2011 04:23 pm
Who has Changed any of the hoses VNT General PT Cruiser Discussions 3 26 Feb 2010 04:39 pm
Neon SRT Radiator Hoses on PT Cruiser Turbo? intim3 Turbo Performance 7 01 May 2009 08:13 pm
Silicone hoses Mean Green Turbo Performance 3 20 Dec 2003 03:23 am
