Stalling while driving and restarting itself
  • 1 Post By ptcruisersteve
Old 06 Jan 2016, 11:43 pm
Unhappy Stalling while driving and restarting itself
I have a 2008 4 cylinder automatic PT Cruiser. About a month ago, it started stalling on me while I was driving it. The first time I was driving on the Highway and all the dash lights turned on and after a few seconds, they turned off and everything was back to normal. It happened about 5 times within about 5-10 mins.
Since then it happens at least once a week. Sometimes the dials all drop to zero before the lights go on. Usually it happens after I have been driving for at least 15 mins. Yesterday the car stalled 4 times within a few mins, after I had been driving for about 25mins. Today it stalled 7 times within 10 mins after I had been driving for 25 mins.
If I pull over and come to a complete stop, I can turn the key and it restarts easily. I have been to the dealership 3 times and they can't find anything wrong. The last time I replaced the battery but it didn't make a difference. I loved this car, but I need a dependable ride. Anyone have any experience with this?
Old 06 Jan 2016, 11:57 pm
Default Re: Stalling while driving and restarting itself
I would suggest first doing a battery load test.
Do you keep a lot of keys on your key ring?
If the battery load test checks out good you might want to check the ignition switch.
Does your radio go on and off when it happens?
chuzz likes this.
Old 07 Jan 2016, 08:09 am
I was going to ask the same question as Steve did about the keys on your key chain. It sure sounds to me like you've got a problem with the ignition switch somewhere. Too many keys can wear one out. I have two keys on my key chain. One for my PT and one for my 200. My house keys and the keys to our church stay on a separate key chain.
Ignorance can be educated, crazy can be medicated but there's no fixing stupid!
Old 07 Jan 2016, 11:42 pm
The radio is not affected at all when this happens. I do have about 8 keys on my key ring so I will remove most of them. I just replaced the battery a couple weeks ago. Not sure what a battery load test is, but would I still need on with a new battery?
Old 07 Jan 2016, 11:49 pm
Maybe I should restate this as not actually stalling unless I am going really slow or are at a stop light. I have restarted it twice, most of the time it just lasts a few seconds and then everything seems normal again, until the time... It happened about 17 times in 5-10 mins this morning and as I was driving near a dealership, I drove straight there. It did it again while I was idling waiting for the door to the service dept to raise, but I accidently shut the engine off when I reach the service station. I left the vehicle there all day, but they said the problem never repeated itself. So that is my 4th trip to the Dealership for this issue.
Old 08 Jan 2016, 01:03 am
This problem has the signature of an intermittent interruption of main power somewhere. It could be from a corroded battery connection. Some have reported that it was caused by a corroded positive starter terminal. The problem could be caused by a bad ground from the negative battery cable to where it connects to the drivers side inside fender. It could be corrosion where the positive cable from the battery enters the TIPM. It could also be a bad connection inside the TIPM. Then some have fixed it with the replacement of the ignition switch. Also very rarely someone would fix it with the replacement of the Instrument Cluster.
I would start with the most common problem which is the battery cables first. After you check to make sure the battery cables are clean and the battery is completely charged you can take the PT Cruiser to an auto parts store like Sears and they will do a battery load test on it for free.
Old 08 Jan 2016, 08:08 am
While I agree with almost everything Steve said in the above post, I have to suggest you stay away from Sears. Even if you bought a new battery from them the day before, if you go back and want a load test on it, you'll be told it's defective and need a new one. Very unscrupulous service departments. Just go by Autozone, Advance or O'Reily. Whichever is closest to you.
Old 08 Jan 2016, 08:28 am
LionPT's Avatar
Part 1
Part 2
The solution was to replace the Ignition switch.
Nexus 5X, Nexus 4, Nexus 7 (2013)
Old 10 Jan 2016, 12:41 am
Smile Re: Stalling while driving and restarting itself
Thanks everybody for your help and terrific suggestions. The videos posted by PTLion are exactly what I have been experiencing.
Tags
electrical, restarting, stalling
Stalling.... Unshriven Tech & Performance Forum 5 14 Mar 2010 11:02 am
Stalling Vicki120 Tech & Performance Forum 4 14 Feb 2010 07:43 pm
stalling natesoukup General PT Cruiser Discussions 3 11 Dec 2009 03:45 pm
Stalling driving, Starting problem KingKole02 Tech & Performance Forum 12 27 Dec 2008 09:08 pm
Stalling sifu_scott Tech & Performance Forum 2 10 Dec 2007 05:35 pm
