low idle
Old 15 Jan 2016, 03:08 pm
Default low idle
My idle is low, about 750 rpm alot of vibration on engine otherwise runs ok, 127000 mi, I replaced the idle sensor it seemed better for 1 day no codes what next
Old 15 Jan 2016, 03:17 pm
Default Re: low idle
750 isn't that low. Did the vibration start after any major work like a timing belt change?
Old 15 Jan 2016, 03:38 pm
I felt it more after the motor mount was replced
Old 15 Jan 2016, 03:42 pm
Also the car is stock and I had the fuel system cleaned and trotted body cleaned, no change, the timing belt was done about a year ago
Old 15 Jan 2016, 03:48 pm
I just checked and have a po325 code
Old 15 Jan 2016, 03:55 pm
If the exact FACTORY INSTALLATION procedure is not followed for replacement of the upper and lower common engine mounts you will get vibration.
As for your DTC clear it and see if returns.
Please watch your engine coolant temperatures during your clearing and rechecking for DTC's. You may also check that your coolant reservoir has the proper amount of fluid.
The idle speed of 750rpm in park or neutral is a good speed.
Old 15 Jan 2016, 04:20 pm
Also the idle is rough and if you are sitting at a light in drive foot on the brake it will stumble and the go back up to 750 and then stumble again
Old 15 Jan 2016, 04:38 pm
Fk5 Fk5 is offline
I think that is the knock sensor. Nitro knows what he is talking about. I'm not sure if it is why he stresses being conscious of your coolant level and temps, but I had recurring coolant leaks my car threw that code a few times. I'm not sure if they were related, but I never did anything to the knock sensor and the code cleared on its own and hasn't returned.
Old 15 Jan 2016, 06:59 pm
Actually with more posted information it sounds more like the IAC or maybe an overlooked vacuum leak. But that would be purely a guess on my part that I rarely do on forums. But you entertained a reason why I suggested watching some thing.
The reason to watch the coolant temperatures are if it is the knock sensor at fault than normal timing and fueling perimeters in the PCM can be interrupted causing a lean condition raising both the EGT's and combustion chamber temperatures which may cause the coolant temperature to raise very quickly.
Old 15 Jan 2016, 10:03 pm
P0325 - Knock Sensor No. 1 Circuit Conditions
Possible Causes:
1. Knock Sensor connector is damaged or shorted
2. Knock Sensor signal circuit open or grounded
3. Knock Sensor signal circuit shorted to return circuit
4. Knock Sensor return circuit is open
5. Knock Sensor not tightened properly
6. Knock Sensor damaged or has failed
7. PCM has failed
If after resetting your DTC's you get the P0325 code back again I would suggest you check the wiring and connector going to your knock sensor.
Stalls at idle. Sometimes. And rough idle scatgo1 Tech & Performance Forum 6 27 Nov 2014 11:04 am
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
WILL NOT IDLE PLEASE HELP ryanfromil General PT Cruiser Discussions 15 07 Apr 2014 02:07 pm
ruff idle at idle only? KRNFIRE General PT Cruiser Discussions 16 23 Jan 2009 09:08 pm
Idle with S1 turbomangt Stage Turbo Kits 10 10 Mar 2005 05:39 pm
