Cruise control stopped working
Like Tree2Likes
  • 1 Post By sanatanadharma
  • 1 Post By ptprice
Old 23 Jan 2016, 09:51 am
War_Eagle's Avatar
Default Cruise control stopped working
Using the cruise control all day, parked the car overnight and now no cruise control? It seemed fine no problems leading up to it quitting. Anyone out there experience this problem? I know that the c.c. doesn't have a lot of items that can fail but I have never touched one.
Any help is appreciated.
2005 Silver GT, auto, black leather, HID Headlights, ST Front sway bar, 215 45/17 tires, dark tinted front windows, stock running gear, sickspeed black pearl shift knob.
Old 23 Jan 2016, 10:15 am
Default Re: Cruise control stopped working
Here's a post that might help diagnose the problem.
Cruise control ?
I don't see a specific fuse for the CC on either the Gen1 or Gen2 models but I'm sure there's another fuse labeled for something else that supplies power. But I did find the wiring diagram for the GEN! cruiser where it says it's the Number #10 fuse for the CC. I'll post it when I print it out.
Old 23 Jan 2016, 12:54 pm
Because Trump
Old 23 Jan 2016, 01:13 pm
War_Eagle's Avatar
Cruise light's up.
Old 23 Jan 2016, 03:14 pm
I would suggest checking the fuse #10 for the cruise control as Sanatanadharma posted.
Last edited by ptcruisersteve; 23 Jan 2016 at 06:07 pm. Reason: Verifying what Sanatanadharma posted
Old 23 Jan 2016, 04:01 pm
Found the wiring diagram for the Cruse Control. It DOES use the number #10 fuse.
Old 23 Jan 2016, 04:25 pm
War_Eagle's Avatar
I am heading out to grab some fuses and start there. I wasn't sure if the cruise control had a fuse, so thanks for the info. I'm actually picking up my set of service manuals tomorrow.
Old 23 Jan 2016, 06:00 pm
ptprice's Avatar
WarEagle, this might sound like a simple "first echelon" suggestion but one that many mechanics ignore as they go about pullin' fuses, checkin' vacuum lines and rippin' out their hair.
I had the same symptoms, CC wise, after a "clown act" replaced SOOO BIG's timing belt. Of course they had to move the CC unit as they did the job the "easy" way by not droppin' the engine for access. When they buttoned it up they forgot to completely seat the electrical lead plug that's socketed into the side of the CC unit. Th CC unit itself is located towards the back of the top of the right strut tower mount. This plug will often appear to be seated but in fact it has a sliding lock to secure it.
W/O that plug seated and the sliding lock engaged your CC can give you all manner of adverse service. From non function, to surging speeds, to unpredictable, dangerous, increases in speeds from 10MPH and higher.
The cheapest and first thing to do is check that out. Good luck.
Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Custom Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. Aluminum Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Touring tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 23 Jan 2016, 06:10 pm
One other member had the Cruise control stop working with the cruise light coming on and found the speed control servo not working properly.
Is your engine light on? If so what are the codes?
cruise control not working psmith32 General PT Cruiser Discussions 5 17 Mar 2016 12:09 pm
Cruise control stopped working Richkent Tech & Performance Forum 8 01 Apr 2014 09:26 pm
One more try... Cruise control not working... Jered General PT Cruiser Discussions 9 27 Jan 2009 03:04 pm
cruise control not working oldone Tech & Performance Forum 1 14 Oct 2007 09:50 am
Cruise Control not working glfnjim Tech & Performance Forum 14 27 Nov 2005 01:45 am
