Water Inlet Tube/Pipe Replacement
Old 25 Jan 2016, 03:40 pm
Default Water Inlet Tube/Pipe Replacement
Just happen to see that this part is very, very rusted with thick flakes. I'm afraid it's very fragile and should replace soon.
What has to be removed to access and replace.
This is what part looks like:
Old 25 Jan 2016, 08:34 pm
Default Re: Water Inlet Tube/Pipe Replacement
You should also have a look at the heater tubes which connect to this pipe. On my car they are heavily rusted too the same as on your inlet pipe. They may need replacing on your car as well. They run along the front of the motor and then bend around and head towards the firewall/heater.
Old 25 Jan 2016, 09:00 pm
myckee: Did you do the work yourself? If yes, any advice on doing this job?
thanks
Water Pump Inlet replacement bama2262 Tech & Performance Forum 8 13 Oct 2017 01:26 pm
Inlet Pipe Darylh Classifieds: Want To Buy 3 12 Feb 2012 01:26 pm
need water inlet neck off of a pt cruiser Boxerjl2 Classifieds: Want To Buy 0 30 Jan 2008 12:45 pm
i want to buy original OEM airbox to turbo tube - pipe mino Turbo Performance 6 02 Nov 2007 07:58 am
Stock turbo inlet pipe wanted. PVO PT Classifieds: Want To Buy 2 01 Aug 2003 01:05 am
