Brake-light problem.
Like Tree6Likes
  • 2 Post By LionPT
  • 1 Post By cruserdad1976
  • 1 Post By Fk5
  • 2 Post By sanatanadharma
Old 23 Mar 2016, 11:36 am
Default Brake-light problem.
Hi!
Im swedish so please bare with me. Im quite bad in english.
I have a PT Cruiser CRD (diesel) 2007.
The brake-lights don't work. The mystery is that the center high mounted stop light works as it should. Does anybody have a tip on what could be wrong? So far I haven't found any broken fuses but mabye I haven't found them all?
Anders
Old 23 Mar 2016, 12:52 pm
LionPT's Avatar
Default Re: Brake-light problem.
Since your 3rd brake light works...the 1st thing to check would be the bulbs in the tail lights.
Old 23 Mar 2016, 12:57 pm
Fk5 Fk5 is offline
Seems remarkably simple, but mine went out almost simultaneously. Third brake light ones went out later, but 2 of them went at almost the same time.
2003 GT 5 speed
162,000 miles
Old 23 Mar 2016, 03:06 pm
They seemed to be OK but I changed them anyway. No result!
Old 23 Mar 2016, 03:35 pm
cruserdad1976's Avatar
do you have power to the sockets??? check with a test light??? if not you will have to just trace the lines to where they plug into a connections take that connection apart clean it and check for power
Old 23 Mar 2016, 04:05 pm
Fk5 Fk5 is offline
I came across this site looking for something else and check it from time to time. They have a step by step and include the 3rd brake light working, regular brake lights not working. Can't hurt. Give it a peek.
AGCO Automotive Repair Service - Baton Rouge, LA - Detailed Auto Topics - How To Diagnose Brake Light Problems
cruserdad1976 likes this.
2003 GT 5 speed
162,000 miles
Old 23 Mar 2016, 04:46 pm
Originally Posted by Exet65 View Post
Hi!
Anders
Third brake is powered by Computer in second generation and I believe power to brake light is from TIPM and with both going bad at the same time is suspect to me. And there is the brake switch located above brake pedal that has a multi contact switch. It reads on the side "If you remove the switch you must buy a new one" one use only. On the switch there is a little lever that you twist after you install to calibrate the brake switch. It cannot be removed and reinstalled without messing up the calibration. (unless your really handy and take it apart and reset the switch from inside so you can make use of the small lever to calibrate it after install)
New switch was $10.00 US
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 23 Mar 2016, 04:50 pm
Because Trump
Fk5 and JoeX like this.
Old 23 Mar 2016, 05:16 pm
Originally Posted by sanatanadharma View Post
Information from page 8W-51-6 of the electrical schematic for the 2007 cruiser
The left and right rear brake lights receive power from the stop lamp control output pin #13 (C3 connector, orange wire) of the TIPM, based upon a signal from the brake pedal switch
One wire only until a splice that is at the rear of the car
The CHMSL (hi-mount stop lamp) receives power from the instrument cluster, based upon the same signal from the brake pedal switch
These are two separately wired circuits from front to rear of car
If bulbs are confirmed good (light up when 12 volts are applied), then check on your TIPM,; maybe a fuse, but I have not researched this
OK research suggest fuse #3 (10 amp)
Schematics sort of confuse me, your good at it thanks for the details.
73 Charger SE
01 Sebring flip
Tags
brake, fuse, light, stoplight
Brake light problem 2004PlatinumTurbo General PT Cruiser Discussions 4 25 Oct 2013 11:45 am
Brake Light Problem Ryan Tech & Performance Forum 1 31 May 2012 03:42 pm
Brake light problem Cruiserbob General PT Cruiser Discussions 3 10 May 2011 12:27 pm
Brake light problem Shiniquiet General PT Cruiser Discussions 4 24 Sep 2010 07:05 pm
Brake light switch problem??? Afitch628 General PT Cruiser Discussions 1 28 Apr 2010 08:34 am
