Problem shifting
Old 03 Apr 2016, 11:38 am
Default Problem shifting
Anyone have problem shifting automatic shifter really stiff?
Old 03 Apr 2016, 01:09 pm
Default Re: Problem shifting
Nope, but you need to be more specific. Are you having trouble getting it out of park and into gear or what? If so, you need to pull the console and check the shift bushings on the cable at the shift connector. If that's okay, remove your battery and check the bushings on the cable where it connects to the transmission. I would suspect one or the other.
Old 03 Apr 2016, 01:26 pm
Automatic shifter
'06 odd shifting problem SilverGT06 General PT Cruiser Discussions 8 01 Mar 2016 09:31 am
shifting automatic transmission problem white2011 Tech & Performance Forum 4 03 May 2015 05:48 pm
manual transmission shifting problem reclasses General PT Cruiser Discussions 14 14 Apr 2015 11:54 pm
Transmission shifting in to low gear problem karleton General PT Cruiser Discussions 9 20 Aug 2010 01:15 pm
RPM's for shifting 5 Speed RJ Tech & Performance Forum 3 17 Apr 2004 08:50 pm
