Can The Harmonic Balancer be Over tightened?
Like Tree5Likes
Old 05 Apr 2016, 11:41 am
Default Can The Harmonic Balancer be Over tightened?
Hello all!
I'm trying to finish up a timing belt replacement.
As I was torquing the Crank (Harmonic Balancer) Pulley bolt, I got a click at 100 ft/lbs. The bolt turned several more times before it consistently clicked at 100 ft/lbs.
However, the balancer is too close to the block now.
Has this happened to anyone else before?
Thanks in advance!
Old 05 Apr 2016, 12:03 pm
Default Re: Can The Harmonic Balancer be Over tightened?
looks to me that it is not on far enough. the alternator should be farther back, and the outer ribs of the pulley should line up with all the other junk. AC/PS/etc.
-is it possible you pulled the outer part off the center hub?
-when you removed the pulley did you pull it from the three center holes, or the outer ribs?
-before you torqued it did you make sure the crank shout and center of pulley were 100% clean and free of burrs?
-before you torqued it did you lubricate the threads and also under the head of the bolt?
Handy_Cruiser likes this.
Old 05 Apr 2016, 12:05 pm
Handy_Cruiser's Avatar
+1
The position of the lower cam sprocket needs to be measured. However, the harmonic balancer has a shoulder where the bolt goes in. This shoulder should fit tight against the end of the cranks. Thus, it should not be able to go in too deep. And once that shoulder is against the end of the crank, no amount of force on the cranks bolt should make the balancer go deeper.
To see if you are still out too far, as Rob suggests, remove the bolt and see if that shoulder is against the end of the crank. If there is a space, it's not on far enough. If the shoulder is against the crank, you need to check that you haven't pulled the balancer apart as Rob suggested.
There's one more issue specific to the crank on a 2007 NA PT. But let's not go there yet....
Old 05 Apr 2016, 12:24 pm
-- I guess it's possible. I will check
-- The three holes with a rental tool
-- it was cleaned but I didn't check for burrs
-- No. I did not lubricate the threads or head. I just put thread locker on it
Thanks for the help!
Old 05 Apr 2016, 12:27 pm
Uh oh!!! It is a 2007
Old 06 Apr 2016, 09:02 am
I did not press the harmonic balancer on, nor did I use an impact. I used a wrench to hold it against the frame and tightened it down with a breaker bar. I then torqued it down with a torque wrench.
I removed it to try again.
Is it OK? Do I need a new one?
Do I need to torque it down differently?
Old 06 Apr 2016, 01:51 pm
I'm not sure if I need a new harmonic balancer or not. I posted pics but they have to get approved by a moderator
Old 07 Apr 2016, 03:59 pm
I just ordered another harmonic balancer. Just in case...
Old 11 Apr 2016, 10:20 am
The harmonic balancer was not pressed on all the way.
rob342 and Handy_Cruiser like this.
Old 13 Apr 2016, 03:01 pm
Yep! That was the problem. Old balancer is installed and now the car is running!
Thanks everyone!
Fk5 and chuzz like this.
harmonic balancer help roadmap Tech & Performance Forum 9 24 Mar 2016 11:53 am
Harmonic balancer Jel3 Tech & Performance Forum 11 23 Sep 2015 06:10 pm
2.4 harmonic balancer install rbtx75098 Tech & Performance Forum 4 19 Aug 2015 06:40 pm
harmonic balancer Jassy General PT Cruiser Discussions 2 01 Jan 2012 12:26 pm
harmonic balancer mdskinner731 Tech & Performance Forum 10 15 Sep 2011 09:04 am
