2007 PT cruiser just cut off while I was driving it
Old 07 Apr 2016, 09:25 pm
Default 2007 PT cruiser just cut off while I was driving it
I was driving my 2007 PT cruiser when it suddenly cut off and would not start again it turned over but didn't start my son used a thing that came up with a code the code was for a cam sensor which I replaced but it still wouldn't start but turns over can someone please help me
Old 07 Apr 2016, 11:27 pm
Default Re: 2007 PT cruiser just cut off while I was driving it
I would suggest always writing down the engine trouble code so you can post the code when you need help. We need the specific code to give you a proper diagnosis of the problem.
I would suggest taking the camshaft sensor off and see if the camshaft is turning when you are cranking it.
What brand camshaft sensor did you install?
How many miles you have on the engine? Has the timing belt been replaced that you are aware of?
I would suggest you introduce yourself to the forum and post some info about your PT Cruiser.
Old 08 Apr 2016, 06:06 am
LionPT's Avatar
Your car will run with a bad Camshaft Sensor, something else is wrong.
Pull the camshaft sensor like 'ptcruisersteve' suggested to see if cam is spinning, the timing belt might have broken.
You can also pull out the rubber plug #2 in pic to check.
03 pt cruiser radio going in and out while driving miztheatre Tech & Performance Forum 1 02 Mar 2015 12:21 pm
How Many Here Have Been Harped On For Driving A PT Cruiser? GreatWhitePT General PT Cruiser Discussions 32 19 Oct 2014 06:32 pm
2007 Driving Lights (Installation Problem) vinzchlortho Exterior Accessories Forum 3 30 Apr 2008 10:59 pm
