Go Back   PT Cruiser Forum > General Forums > Tech & Performance Forum
Going from a Getrag 288 to a NV-T350
Like Tree3Likes
  • 3 Post By rob302
Old 10 Apr 2016, 07:51 pm
Default Going from a Getrag 288 to a NV-T350
Has anyone ever performed this swap? Say take a NV-T350 from a neon or numerous other vehicles and swap it into a manual PT that came with a Getrag 288? The reason I ask is I keep seeing 3.94 gears for those transmissions, lightweight flywheels (single mass, not this dual mass crap), numerous aftermarket clutches, and just overall a larger aftermarket support it seems. I think having some 3.94 gears would be awesome for the track
I don't know much about the NV-T350 so perhaps it is an inferior transmission but I figured I would ask if anyone has performed this swap. I know the T350's came in the 01-02 PTs so I can't imagine it being too difficult of a swap other than different axles, clutch, flywheel, some bolts, and I would think the shift linkage would be fairly similar but I could be wrong.
If anyone has experience with this it would be greatly appreciated.
Old 11 Apr 2016, 02:41 am
_PTGT03's Avatar
Default Re: Going from a Getrag 288 to a NV-T350
i heard the axle length's aren't going to line up
and the 288 is geard optimally for the cruiser's size and weight
2003 GT M/T in Onyx Green Pearl on Michelin Pilot Sport AS 3 Plus Tires 205/50ZR17. Dark Slate Gray Interior. OEM cargo net, parcel shelf, slush mats and trunk protector, mud flaps, mopar subwoofer. Platinum edition pedals, Neon SX 2.0 steering wheel with black+grey wrapped leather cover. Generic lowering springs, KYB gas shocks, Valeo solid flywheel conversion and clutch kit. Urethane insert engine mounts. Energy suspension full body urethane bushing kit. Chrysler premium front speakers, Jenson 6x9 rears. Boston Audio 4x55W amp. Panasonic head unit with xtenzi bluetooth. 300W AC power inverter. Escort 360max and Escort Shifter ZR4, dual front+rear dash camera. stage 1 blow off valve and syked tune computer . Boost and oil pressure gauges with Turbo-Timer. Needswings 3" exhaust elbow, Electric valve actuated Y-pipe with catalytic converter. To do: coilovers, 2step controller, quaife diff, Air-Fuel Meter
Old 11 Apr 2016, 06:41 am
SPLNeon's Avatar
It can be done. Not sure if you can still use the intermediate shift. The n/a PT's had that transmission, so just find a donor car and swap pieces. You may have to swap shift cables too?! If you make big power and run out of gear, snag a 3:55 fd ratio Trans from a ln 01 + neon.
Fastest fwd PT Cruiser in Canada
Competition's paying the price.
03 PT GT. DSI canned tune, Weight redux, MH Racemaster Slicks/Rota Slipstream 15" 11.89at 115mph 1/4 mile
96 SOHC Neon Turbo
08 CSRT4. Realtune MS1K v1 pcm stg0 NSRT4 Injectors.
Old 11 Apr 2016, 08:07 am
SPLNeon's Avatar
Just remember, the T350 transmission is weaker, bit more plentiful.
96 SOHC Neon Turbo
Old 19 Dec 2017, 04:37 am
No intermediate shaft, direct bolt on. You will need a south bend stage 2 clutch for the nvt 350 to have the same strength. You will need unequal length cv axles from any neon or Pt cruiser. You can go with the 3.55 or 3.94. Just keep in mind 3.94 will be hell at highway speeds.
Old 19 Dec 2017, 09:45 am
In theory, you should be able to use the intermediate shaft from an automatic turbo car with the nv350. The logic is as follows: Since the axles used for both manual and auto non-turbo cars are the same part, with of course same length etc, that means the diff is located in the same place with approx. same dimensions on both allowing the same axles to be used. And, since the Automatic used in both turbo and non-turbo is the same (individual internal parts are irrelevant for this discussion), then it follows that the intermediate shaft system used on the automatic turbo cars would be a direct swap into manual non turbos with an NV350.
Old 19 Dec 2017, 11:55 am
rob302's Avatar
ALL PT's came from the factory with a 3.94 - the 2001 had a slightly taller 5th gear that would slightly lower highway rpm.
___________________
there is a T350 version intended for a 1.6L export PT that has a 4.13 final drive. if i still had my non turbo PT running, this is the version i'd be after.
read this before diving in.
FWIW you're not gaining much gear with the 3.94 because your first gear is numerically higher. i'd rather have the strength
GT
1: 3.92
2: 2.21
3: 1.46
4: 1.11
5: 0.88
Final Drive Ratio: 3.29
NA
1: 3.50
2: 1.95
3: 1.36
4: .97
5: 0.81
Final Drive Ratio: 3.94
Old 19 Dec 2017, 12:17 pm
rob302's Avatar
^ just wasted half an hour replying to a 1.5 year old thread
Getrag swap LRSRTGT General Turbo Discussions 7 19 Feb 2016 11:01 pm
drain plug T350 trans wb2kki General PT Cruiser Discussions 4 14 Apr 2014 12:27 pm
Getrag Shifter 767skyking Classifieds: For Sale/Trade 2 31 Oct 2012 01:11 pm
Manual Getrag Tranny??? Ironman Tech & Performance Forum 10 22 May 2011 10:02 pm
bleeding getrag slave thumperz Tech & Performance Forum 0 28 Nov 2009 03:19 pm
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
