Setup to use E85
Like Tree5Likes
Old 14 Apr 2016, 01:45 pm
Default E85
What should I do to make a proper installation to use ethanol ?
Can I tune my PCM with Diablosport Trinity ?
PT CRUISER 2L 2000 STARTECH
PT CRUISER 2,4L GT 2004
CHRYSLER VOYAGER 3.3 1993
CHRYSLER VOYAGER 3.8 AWD 1997
CHRYSLER VOYAGER 2.5 CRD 2003
Old 14 Apr 2016, 03:39 pm
Default Re: Setup to use E85
you could.
Old 14 Apr 2016, 03:44 pm
how ?
should I change something else ?
Old 14 Apr 2016, 06:24 pm
This subject is far to large to talk about until you are ready to actually do it. You should in the mean time learn as much as you can about it before deciding to use it.
There is at least 2 PT Cruiser members that have used and may be still using it?
But I can tell you ion both cases their PT Cruiser have been modified and are in excellent running condition with many mods.
It will need calibration adjustment done either with a PCM access device or from someone like Syked tuning Syked Ecu Tuning | Dodge Tuning Software
E85 and Methanol users above 60% are both a PIA IMHO for a ECU/EFI calibrator. You also need to be able to DATA and even a chassis DYNO at some point to check everything out.
Nothing personal and don't take this wrong but you really should get your PT Cruiser at the first stage of your upgrading level and then think about exotic fuels.
I am working right now helping a professional racer with his ECU calibration recommendations and the use of meth at levels 80 to 100%, OMG what a PIA!!!!!!! and mostly will be actually doing them in the near future. If I get the new program to do so.
Old 14 Apr 2016, 07:02 pm
As the other guy said, you should read up on it. There isn't a lot of information here, but there is quite a bit of information on the srtforums as well as others. I too have plans to do this. Time will tell if I do actually do it or not, but it has been an interest of mine for a while.
At the very minimum, you will need a set of larger injectors (~750cc) and a custom tune. There is a user on the srt forums called Duster360 and he has supplied many of those guys with custom DS tunes to run e85. I likely will buy one from him, should the time arrive in the future.
Anyway, definitely read up on it.
NitroPT and Pippov like this.
Old 15 Apr 2016, 12:34 am
Thank guys I ll Check it
And read on the srt forum
Old 15 Apr 2016, 12:15 pm
wingman55's Avatar
Just to add my 2 cents: I have a 2005 Dodge Stratus that is Flex Fuel. I have tried the E85 in it a couple times.
First off, they recommend that if you are going to use that fuel for any length of time, you will have to use special oil in the crankcase.
Second, yes, E85 is less expensive than regular gas, but your gas mileage will go down by at least 15%. I checked it and it did.
SO, that's something to think about as well.
(Plus it smells weird when you burn it.)
2006 Limited Edition, Inferno Red, 5-speed, Bassani dual exhaust, Chrome backup light bezels, taillight trim, fuel door, antenna mount, Ventiports, door spear covers & hood prop. Silver painted lower front grille. American Racing 383 Casino wheels, w/Chrysler emblems, '02 engine cover, PT Cruiser mudguards, cargo mat. EGR Window Visors, dark gray lock pulls, dual horns, Fuzzy Dice, flames and MOPAR emblems added to front door logos, gold Chrysler emblem on rear hatch. Upgraded to RAK radio with 6 CD changer, Cassette Tape and RDS info. Name: "FIREBALL" I bought it Aug 10, 2015, with just over 35,600 miles on it.
2004 Limited Edition Platinum Series, Graphite Metallic, Standard Turbo, automatic, RBQ radio with Sirius Radio & 6 CD changer, VentShades, chrome exhaust tip, door spears, grille inserts, door lock pulls, bright pedals and steering wheel spokes. Red spoiler from a donor PT. Known as: "The RATMOBILE" I bought it Apr 28th, 2016 with 62,400 miles on it.
Old 15 Apr 2016, 12:20 pm
In France 1l of 95 is 1,25 euros . 1l of E85 is 0,65 euro
And my other pt is full e85 since more than 20000 km, I dont have any trouble except the engine light on for the injector
Old 15 Apr 2016, 12:36 pm
Originally Posted by Pippov View Post
In France 1l of 95 is 1,25 euros . 1l of E85 is 0,65 euros
you save .6 euros per litre, but you burn 30% more fuel. so technically you only save .3 euros per litre, minus the cost of bigger injectors, the tuning hardware, and the cost of having it tuned. IMO it will be a lot of driving before you make those costs up
have you tried mixing the e85 and gas on the other PT to see if you can save a little while still running correctly?
Old 15 Apr 2016, 12:48 pm
you should get a FORD!! after i throw my 90lb deka injectors in, all i need to do is choose from this drop down menu to change my fuel (:
Exhaust setup GtskinnerPt Tech & Performance Forum 12 21 Apr 2013 11:43 am
My New Exhaust Setup niel Exterior Accessories Forum 20 12 Dec 2012 02:01 am
good setup? czkoma General Turbo Discussions 0 21 Jun 2008 01:38 am
Starter Setup PTmodrod Tech & Performance Forum 2 29 May 2008 06:04 am
Proper BOV setup!!?? COP TZER Turbo Performance 2 21 Aug 2003 07:07 pm
