P0134-0135 after Changing Valve,Gaskets
Old 15 Apr 2016, 06:32 pm
ptptptpt's Avatar
Question P0134-0135 after Changing Valve,Gaskets
Hello from overseas,
My car is 2001 PT Cruiser 2.0L Engine with Auto-Trans. 130K miles.
My cars Timing Belt has broken. Then, all of Valves, Valve Gaskets, Sparks, Timing Belt Set-Tensioners, Head Gasket Set has been replaced. There were no leak or crack at Cylinder Head. MAP SENSOR has been replaced.
After repairing, Car did 2000 miles, oil and coolant levels are ok.
But P 0134-0135 Engine Code appeared and Engine Light comes on.
Sometimes car stalls and does not run normally at full at gas, its like engine will stop. And exhaust smells like Rich smoke..
What maybe the reason of it ? Bad 02 Sensors or bad Timing belt repair?
My car has no CAT about 4 years but there was no error code before Timing Belt Broken. Its appeared after car repaired for Timing belt issue. Thats why I confused. Can it be a chance or related with mechanic's labor?
Thank you for your help!
Old 16 Apr 2016, 05:36 am
Default Re: P0134-0135 after Changing Valve,Gaskets
First thing I'd do is a fuel pressure check on the car. Should be somewhere in the 55-57lb vicinity. If that's okay, check for a leaky fuel injector or clogged injector. I'm not a mechanic, but I don't believe in coincidence either.
Old 16 Apr 2016, 06:35 am
Check the coil connection or if you can or swap it for a known good one for testing. Sounds like the coil (Spark) may be breaking down under load (heat).
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 16 Apr 2016, 09:36 am
P0134 - O2 remains at center conditions:
Possible Causes:
1. Exhaust leak present in exhaust manifold or exhaust pipes
2. O2 element is fuel contaminated or has deteriorated
3. O2 signal circuit or ground circuit has high resistance
4. PCM has failed
P0135 - O2 Heater circuit conditions:
Possible Causes:
1. ASD relay output (power) circuit to the heater is open
2. O2 heater ground circuit is open
3. O2 heater element is damaged or has high resistance
4. PCM has failed
Keep in mind most of us don't work on 2.0L engines.
I would suggest first checking the resistance on the wires going to the 02 sensors.
IF that is okay I would suggest checking the 02 sensors.
Changing spark plugs, do I need new intake manifold gaskets? Sea_Shells Tech & Performance Forum 4 23 Jun 2015 08:21 am
Changing the valve cover gasket on a 03'. allhale09 Tech & Performance Forum 10 22 Dec 2013 09:19 pm
Valve cover & intake gaskets sets Koch Classifieds: Want To Buy 4 25 Feb 2012 11:36 am
Difference in valve cover gaskets PTCruisinTurbo General Turbo Discussions 5 08 Feb 2011 06:50 pm
Changing the PCV Valve emery Tech & Performance Forum 2 07 Dec 2001 05:05 am
