What is the oil pressure in a 04 PT cruiser
Like Tree5Likes
Closed Thread
Old 24 Apr 2016, 03:53 pm
Default What is the oil pressure in a 04 PT cruiser
I mounted a oil gauge on the dash and got it all hooked up today and started the car up let it warm up and when I looked at it it was at a little over 25 psi point and when I revved the engine at 3,000 rpm the oil gauge showed at 75 psi. What do you guys think of the pressure the gauge don't show numbers by every tens. I think the gauge was tell me about 30-35 oil psi I'm not sure exactly. Sorry
Old 24 Apr 2016, 05:49 pm
Default Re: What is the oil pressure in a 04 PT cruiser
Without any details of the engine, mileage or what oil you used it's very hard to give you an answer.
Old 24 Apr 2016, 06:40 pm
I got 103,900 miles and I just put in Valvoline 5-w30 full synthetic oil, what kinda engine details do you need?
Old 24 Apr 2016, 08:04 pm
i'd say you're good. why are you questioning it? are you having some sort of an issue?
Old 25 Apr 2016, 03:48 am
Attachment 16644
The reason I'm asking for is because there is a soft tapping in the engine so I was going to replace the lifters and someone told me that I should check the oil pressure before replacing the lifters, they said if I had low oil pressure and changed the lifters I'll still have the same problem. That's why I'm asking. But why does the gauge say between 38-41 about at idle when warm when the book says 4 psi?? I'm confuse about that is there something I did wrong or use the wrong oil or something?
Old 25 Apr 2016, 10:00 am
response removed because the guy below me offers better and more knowledgeable advice
Old 25 Apr 2016, 10:25 am
The oil pumps used on the 2.4 were complete over kill. Because it is a very close machined oil pump assembly low rpm oil pressure is common.
In fact they will produce so much oil pressure that if you sustain a high RPM over a short period of time you can effectively* drain the sump and have all your oil in the head valve cover are. But don't worry only a few PT Driver would ever experience that. lol
*Chrysler saw this as a problem and did a general fix of a small plastic restrictor year ago placed in the block during assembly.
*See also DCR website.
Imo if you are hearing the HLA (hydraulic lash adjusters) it may be more from oil varnish on the lifter itself or the lifter bore from lack of a good oil/filter maintenance schedule over the life of the engine . Try some Marvel Myster oil before the next oil change and add it as part of the oil at the next oil/filter change.
Old 25 Apr 2016, 10:48 am
cruserdad1976's Avatar
Dang I had no idea any body else used Marvel Mystery Oil and to be honest I have no idea what its supposed to do but what I do know is and this(and I am not trying to start a discussion) I add 1 quart of Mystery oil and 1 quart of Lucas and 3 quarts oil and a use a wix oil filter every month on my dd it make me feel good it must be ok as most of my rides have way over 100,000 and some over 200,000 so for ME it worksI have opened up a few of my motors and while they are not sparlely clean there are very few globs of think burnt oil or whatever that stuff is
NitroPT likes this.
Old 25 Apr 2016, 10:57 am
I hate feeling like an "old Timer" but I have been using Marvel Mystery oil for years on so many project not only car related.
I am sure Gold2006 may have a different opinion and even some technical information about it and maybe some better Amzoil Products that might work in its place. Never the less I will still use my MMO for many project.
Old 25 Apr 2016, 11:17 am
Thanks NitroPT!
I like to start with a clean fuel intake, combustion chamber and fuel injectors using http://www.amsoil.com/lit/g2543.pdf?zo=1181889 .
Also with a clean engine AMSOIL Engine and Transmission Flush.
Then follow with your favorite lube meeting factory specifications. Mine are:
2004 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [B]
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
Maximum Performance Signature Series 5W-30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W-30 Synthetic Motor Oil (OEFQT) Above 0 F......10W-30
Below 100 F......5W-30 [1]
Manual Transmission,A578 (5-SPD)......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Automatic Transmission,40TE......AP4
Automatic Transmission,41TE......AP4
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [2]
Clutch Fluid......HB
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [3]
[1] SAE 5W-30 is preferred.
[2] Hydraulic Brake Fluid, DOT 3 P/N 04318080AC, meeting MS-4574
[3] ATF+4 Automatic Transmission Fluid
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EA15K51) [1]
Oil Filter WIX 51374 Oil Filter
Oil Filter WIX 51348 Oil Filter
Air Filter WIX 46699 Air Filter
Transmission Filter WIX 58934 Trans Filter
[1] Replaces the Ea15k33, which will still work for this vehicle
CHASSIS LUBRICATION:
0-2 Fittings, 0 Plugs..........LB
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLC3P)
Synthetic Water Resistant Grease (GWR3P)
DOMINATOR Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
CAPACITIES:
Engine, with filter..........5.1 quarts [1]
Cooling System, Initial Fill..........6.6 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 40TE Initial Fill..........4 quarts
Automatic Transmission, 41TE Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed 41TE..........8.6 quarts
4 speed 40TE..........8.6 quarts
Manual Transmission, A578 (5-SPD)..........5.1 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....20 ft/lbs
Manual Transmission G288
Fill Plug 29-35 ft/lbs
Drain Plug 29-35 ft/lbs
Manual Transmission T350
Drain Plug 10 ft/lbs
OTHER TOP QUALITY PRODUCTS:
By-Pass Oil Filters
Diesel Injector Clean
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
I can get you the best prices and delivered to you in 2 business days. 713-301-1872
NitroPT likes this.
Closed Thread
My 04 PT Cruiser don't have a Power Steering Pressure switch??? Bandit2014 Tech & Performance Forum 15 23 Aug 2015 01:12 pm
2001Pt Cruiser Power Steering Pressure Hose jholl Tech & Performance Forum 3 06 Aug 2014 10:54 am
[How To] Change the Oil Pressure Sending Unit/Switch on 2005 2.4L Turbo PT Cruiser ingram87 Tech & Performance Forum 2 02 Aug 2014 06:14 pm
02 pt cruiser, just purchased, no oil pressure 71cuda2 Tech & Performance Forum 23 28 Apr 2014 06:00 pm
2006 cruiser power steering high pressure hose TOMisKING Tech & Performance Forum 0 01 May 2010 03:38 pm
