Pt cruiser throwing 10 codes
Like Tree5Likes
Old 24 Apr 2016, 08:14 pm
Default Pt cruiser throwing 10 codes
Hi everyone, my girl just bought an 06 PT GT Convertible automatic non-autostick with 93k miles. As soon as she brought it her driveway the CEL light came on. I scanned it the next day and here's the horror I saw:
P0551- Power Steering Pressure Sensor/Switch Circuit Range/Performance
P0700- Transmission Control System (MIL Request)
P1603- Loss of SDM Serial Data
P0480- Fan 1 Control Circuit
P0513- Incorrect Immobilizer Key
P1188- EOT Sensor Ckt. High Voltage
P0562- System Voltage Low
P0218- Transmission Fluid Overtemperature Condition
P0882- TCM Power Input Signal Low
P1684- Driver 5 Line 4
The ONLY symptom we notice is sometimes the car wont shift. It will go from 0-60 in the same gear wont shift up or down. This only happens sometimes. Radiator fan also works (so I dont know why P0480 is on unless it's for a different fan).
Randomly while the vcm scanner is hooked up several codes will disappear for a second, leaving only these showing:
I'm going to be looking for corroded wiring tomorrow as best I can, any other ideas as to what is going on? Thanks!
Old 24 Apr 2016, 08:39 pm
Default Re: Pt cruiser throwing 10 codes
I would suggest checking the ground wires going to the inner driver's side fender. there are several ground wires going to a lug and bolted to the inner driver's side fender. The connections get corroded and then you start loosing ground to several modules.
If that is okay I would suggest you check your battery and battery cables. Make sure you do a battery load test with the battery still in the PT Cruiser. Make sure your battery cables are clean on both ends. On the positive battery cable there is additional wire going to it and make sure its making good contact. The PT Cruisers are sensitive to voltage drops and usually you get plenty of engine trouble codes when it happens.
Old 26 Apr 2016, 09:35 am
@ptcruisersteve
Thanks for the info, I looked over everything starting with corrosion on grounds, then wires, then the actual connectors. Everything was fine. Then I switched the battery from my car to her car since my battery was much bigger and I New it was working fine. No more problems all day. So we got a new battery and so far all is well, thanks for the info!
Old 26 Apr 2016, 09:40 am
I did not read where you cleared all the DTCs using a scan tool at the diagnostic connector and drove the vehicle about 30-50 miles and rechecked for DTC(s)?
Always the first thing that should be done ^^^^^^^^^^^^^^^^^^^^^^^
cruserdad1976 and chuzz like this.
Old 27 Apr 2016, 10:21 am
@NitroPT I did do that and they all came back, just forgot to mention it. Second day on the new battery and so far only the Fan code has come back, so going to replace that soon
Old 27 Apr 2016, 10:37 am
The condition you posted with all the variances in the DTC of which most are not related would have a failing PCM, bad connectability with the PCM connectors or a connectability problem with the battery.
You are most likely posting your own cure by removing and reinstalling the battery ,the simple act disconcerting and re connecting the primary cables was probably one thing that helped improve your connection issue.
If anyone uses another donor vehicle, that battery should be first charged and load tested before using in any other vehicle as a problem resolver to rule out yet another electrical condition being introduced.
chuzz likes this.
Old 27 Apr 2016, 04:44 pm
These three codes have returned, along with a new one.
U0101- Lost Communication with TCM
The car is not going into limp mode anymore so far. I have thoroughly checked all the connectors and wiring from the trans to the TCM, Ive taken a wire brush and cleaned all the terminals.
We are having an issue where moments after the key is in the ON position (with the car off) the battery light will pop on. I'm unsure of whether this could have anything to do with the codes. The new battery is a 26R 715ca 575cca
Old 27 Apr 2016, 05:34 pm
Handy_Cruiser's Avatar
Here's an interesting little piece on this:
What is the dealer code p1603 for a pt cruiser
Old 27 Apr 2016, 09:46 pm
I would suggesting checking the ground wires going to the PCM
Also suggest checking the fused Ignition Switch (Off,Run,Start) circuit wires from the TIPM to the PCM. You might have resistance or a break in the wires involving the Fused Ignition Switch (Off, Run, Start) circuits.
Make sure you check this circuit before considering replacing the PCM. Others have replaced the PCM and still had the problem so you need to verify the Fused Ignition Switch (Off,Run,Start) circuit is working properly.
Old 04 May 2016, 05:39 am
Sorry haven't been back in a while, just was able to look at the car yesterday. Couldn't find any wiring issues, my mechanic buddy looked at it also and said he was 99.9% positive it needs a pcm. That being said, does anyone know if any pt turbo auto pcm 06 and up will work, or does it need to be an 06?
throwing codes 0121 & 0129 cannesman Tech & Performance Forum 3 05 Apr 2015 04:05 pm
PT Throwing Error Codes samxhalo General Turbo Discussions 9 27 Dec 2014 01:28 pm
Help with '01 NO spark/Start/throwing codes.. PLEASE!! domsob1974 Tech & Performance Forum 22 02 Sep 2014 09:26 am
I'm throwing some codes sleepy General Turbo Discussions 1 29 Sep 2012 10:14 pm
WE'RE THROWING IN THE TOWEL !! excelawashguy Vendors & Buyers Forum 5 19 Mar 2006 11:43 am
