Cruise Control Issue
Like Tree3Likes
  • 3 Post By OurPTGT
Old 25 Apr 2016, 12:33 pm
Default Cruise Control Issue
Looking for some suggestions to cure this issue. 2005 GT turbo, the cruise control cycles. Set at 75 mph and it drifts down to 66-68 mph after a minute or so. Set it back at 75 and it drifts back down 66-68 mph. Any help will be appreciated. Thanks
Drive Safe Be safe
hob
Old 25 Apr 2016, 01:02 pm
LionPT's Avatar
Default Re: Cruise Control Issue
Does it work fine at other speeds..??
Old 25 Apr 2016, 02:32 pm
check the vacuum lines to the CC solenoid canister. There's also a check valve on the brake booster and a vacuum line that runs across the firewall to the CC.canister.
I haven't worked on a PT in many years so this from RAM (rarily accessed memory)
'03 GT base w/175k and a 2 speed autostick (read: trans is shot) and powered by a hybrid MOPAR S3 with DSP untuned
1st Forward Motion E1 powered PTGT w/Psi-Fi Power pack fuel tuner back in '07
FS: '03 GT Elec Blue w/rear suicide doors or '03 auto PCM, S3 turbofold, WGA, 3.5" o2 & 3" DP - make offer
Old 25 Apr 2016, 07:26 pm
Usually use the cruise control on interstate. I really haven't tried it at a lower speed. Next time I get a chance I'll give it a try. Also I'll check out the vacuum hoses, although there are only 32,000 miles on the car, the hoses are over 10 yrs old so they may be cracked from age. I'll have to check it out.
Thanks for the help.
Be Safe Drive Safe.
hob
Old 26 Apr 2016, 03:49 pm
Heading to NY, since the car will garaged I decided to resolve cruise control issue when I get back down to Florida. Didn't want anyone to think I wasn't grateful for the quick responses.
Be Safe Drive Safe
hob
Old 09 May 2016, 03:17 pm
uncomn's Avatar
my cruise control is not working on this car since i bought it few months ago, being in and out of the bonnet doing the plugs and leads and coil recently ive got to notice the cruise cable is somewhat slacker and loose, than the throttle one....is this normal? could be the cause of the issue back to that unit in the corner?
2002 Touring 2.0 Steel Blue Pearl
2005 GT 2.4 Dark Plum Pearl
Cruise Control Issue Jim_b General PT Cruiser Discussions 9 12 Feb 2016 10:24 pm
Cruise Control jaded13640 General PT Cruiser Discussions 4 15 Aug 2014 09:17 am
Cruise Control Issue - Stumper... TurboDucky Tech & Performance Forum 7 16 Sep 2013 09:11 pm
Cruise Control chasjr1450 Tech & Performance Forum 4 13 May 2012 07:15 am
Cruise Control TurboNNN General Turbo Discussions 10 07 Jul 2003 02:37 pm
