no power issue
Old 29 Apr 2016, 07:58 am
Default no power issue
i got a 04 pt cruiser limted found out it had bad battery i jump started and it crank a couple times then it went dead still got lights dash lights. check starter witch is good. all fuses good but geting no power to asd relay and the obd port wont work. the red light on the guage cluster is soild red when key in start postion could that be the problem. im new to pt cruiser and usaual i can figure out problems but this got me stumped thanks
Old 29 Apr 2016, 08:41 am
Default Re: no power issue
Without a history of the PT Cruiser you might have more than one problem. I would start by trying to unlock the security immobilizer. Were you using the same key that you usually use to start it?
I would suggest trying to unlock the immobilizer by hooking up a battery charger to the battery, turn on the ignition switch to the "On" position, wait 3 hours, turn the ignition switch off, take off the battery charger and try to see if you can start the engine.
Old 29 Apr 2016, 11:12 am
i try that and i dont know much about the car i just got from a salvage yard as a rebuildable they said it ran and drove but sat few mths i been useing the same key to start it. thanks
Old 30 Apr 2016, 05:25 pm
i tryed to reset the key didnt work i still got soild light on. any other way to reset it or is something in the system thanks
Power Steering Issue jgtidwell Wheels, Tires, Suspension 1 10 Apr 2015 03:56 pm
Power Steering Issue now Clayman1000x Wheels, Tires, Suspension 8 17 Oct 2014 07:09 am
Power steering issue plabian Tech & Performance Forum 4 07 Oct 2014 11:35 am
Power Mirror Issue PTVibe General PT Cruiser Discussions 3 23 Sep 2012 04:25 pm
power window issue djd General PT Cruiser Discussions 6 14 Feb 2010 12:40 pm
