Additives ?
Old 29 Apr 2016, 09:01 am
Default Additives ?
The Car has 67k miles on her. She has a few issues like most, but I was wondering what your thoughts are about adding additives, like ZMax transmission fluid etc.
Old 29 Apr 2016, 10:02 am
Default Re: Additives ?
I recommend to do a standard filter and fluid change. Get a NEW transmission pan from doorman that has a drain plug. Then use only* recommended fluid replacement. Keep to a schedule and do the next change at between 12 and 24,ooo miles. Or definitely at your 100k complete service millage.
The only enemy with w PT Cruiser ATX is neglect of basic servicing.
As for additives I suggest to talk to * Gold2006.
He will be on shortly to respond.
Old 29 Apr 2016, 01:03 pm
. As a retired Shell Oil chemist and current AMSOIL Direct Jobber, I, transmission oil, and OEM manufacturers discourage use of additives which will void their warranties if the cause of failure. Use a top of the line transmission fluid that meets OEM standards. Mine, of course, is AMSOIL after using the AMSOIL Transmission Flush and a new filter. If you provide the 8th character of your VIN, I can be more specific.
Old 29 Apr 2016, 01:51 pm
or me. i've blown up every automatic i've ever owned
Old 29 Apr 2016, 04:09 pm
I bet you can tare up a anvil too.
LionPT likes this.
Old 29 Apr 2016, 05:33 pm
Rob, you sound like a cousin of mine. When we were kids, he could tear up a steel ball with a paper hammer! LOL
Old 30 Apr 2016, 07:28 am
Thanks Gold2006 for the info. The car has 67k miles now, I had the filter and fluid (ATF6) changed at 61k. Gasket was $9.14, ATF6 (5qts) was $44.75, Remove and Replace Labor was $95.00, Shop supplies was $14.95 Total, w/tax was $173.72. Vin # is 3C3JY45XX7T585228 ,and I still have a slight 'thump' noise when the car down shifts into first.
Old 30 Apr 2016, 08:34 am
When did you notice the "thump?". By ATF6, do you mean GM DEXRON 6? If so that is the wrong fluid. It is a low viscosity ATF and may be the reason for the "thump". Your car requires CHRYSLER ATF + 4 and the correct AMSOIL ATF is listed below. Also it takes 8.6 quarts for a total fill, at least 10 quarts for a complete flush. Hope this helps.
2007 CHRYSLER PT CRUISER 2.4L 4-cyl Engine Code [X]
LUBRICANTS & FLUIDS:
Engine Oil
Grade 1......API*
Maximum Performance Signature Series 5W-30 Synthetic Motor Oil (ASLQT)
Performance Plus XL 5W-30 Synthetic Motor Oil (XLFQT)
Performance OE 5W-30 Synthetic Motor Oil (OEFQT) All TEMPS......5W-30, 5W-20 [1]
Manual Transmission,T350......AP4
All TEMPS......
Signature Series Multi-Vehicle Synthetic Automatic Transmission Fluid (ATF) (ATFQT)
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT)
Manual Transmission,A578......AP4
All TEMPS......
Automatic Transmission,40TE......AP4
Fluids
Brake Fluid......HB
AMSOIL Brake Fluid DOT-3 (BF3SN) [2]
Clutch Fluid......HB
Power Steering Fluid......AP4
OE Multi-Vehicle Synthetic Automatic Transmission Fluid (OTFQT) [3]
[1] Check oil fill cap for proper engine oil viscosity usage.
[2] Hydraulic Brake Fluid, DOT 3 P/N 04318080AC, meeting MS-4574
[3] ATF+4 Automatic Transmission Fluid
FILTERS:
Oil Filter Absolute Efficiency Oil Filter (EA15K51) [1]
Oil Filter WIX 51374 Oil Filter
Oil Filter WIX 51348 Oil Filter
Transmission Filter WIX 58934 Trans Filter
[1] Replaces the Ea15k33, which will still work for this vehicle
CHASSIS LUBRICATION:
0-2 Fittings, 0 Plugs..........LB
Synthetic Multi-Purpose Grease NLGI #2 GC/LB (GLC3P)
Synthetic Water Resistant Grease (GWR3P)
DOMINATOR Synthetic Racing Grease NLGI#2 GC/LB (GRGCR)
CAPACITIES:
Engine, with filter..........5.1 quarts [1]
Cooling System, Initial Fill..........6.4 quarts
Passenger Car & Light Truck Antifreeze & Coolant
AMSOIL Antifreeze and Engine Coolant
Automatic Transmission, 40TE Initial Fill..........4 quarts
Automatic Transmission, Total Fill
4 speed 40TE..........8.6 quarts
Manual Transmission, A578..........5.1 pints
Manual Transmission, T350..........5.1 pints
[1] After refill check oil level.
TORQUES:
Oil Drain Plug.....20 ft/lbs
Manual Transmission T350
Drain Plug 10 ft/lbs
OTHER TOP QUALITY PRODUCTS:
By-Pass Oil Filters
Diesel Injector Clean
Cold Flow Improver
Cetane Boost Diesel Fuel Additive
PI Performance Improver Gasoline Additive
Product Recommendations and Drain Interval Chart
Old 30 Apr 2016, 08:35 am
ATF6
http://www.genecards.org/cgi-bin/carddisp.pl?gene=ATF6
http://www.nature.com/ng/journal/v47...l/ng.3319.html
Old 30 Apr 2016, 02:17 pm
Thanks Gold2006 for ALL the info. I took the car to a reputable Trans shop for the change. That's who put in the ATF6. I'm going to find out this on Monday. And Crewzin, are you kiddin me!
Fuel additives/injector cleaner? wayne2001ptcruiser Tech & Performance Forum 4 05 Mar 2014 01:47 pm
Engine(oil) Additives(treatments) wayne2001ptcruiser Tech & Performance Forum 33 03 Mar 2014 03:06 am
Techron, Gas Additives Etc Busa_Powered General PT Cruiser Discussions 15 06 Jun 2012 10:42 am
