Engine won't start no compression I think
Like Tree2Likes
Old 01 May 2016, 06:40 am
Default Engine won't start no compression I think
My 2002 pt cruiser was running really rough ie hesitating, misfire ect. I changed the plugs and wires and once I got it all back together started it right up. I let it run for about 10 minutes then decided to take it for a drive. Ran it through town for about a half hour then decided to take it on the highway . I was going up the on ramp and once I got to about 45mph the engine just cut out (meaning just stopped running). I checked the codes (got p1684, p0340, p0303, and p0401). When I try to start the car it sounds like the starter is turning the engine but doesn't seem to be getting compression.I checked wirws and plugs and i am getting spark. I ended up changing the ignition coil (just incase) the camshaft position sensor as well. Checked all the wires to everything and it all looks good. Timing belt is good as well (just got replaced when the water pump got replaced). Just getting frustrated and seems I'm putting money into things that is not making it run. Please help!!!!
Old 01 May 2016, 07:37 am
Default Re: Engine won't start no compression I think
If you think you not getting any compression you need to take the intake off and do a compression test on each cylinder. First I would double check that the timing belt was still good and still turning the cams. Did you do the timing belt your self, did you see the old parts after they were removed?
chuzz likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 May 2016, 07:53 am
I agree with Joe. It sure sounds like the timing belt is either stripped or the tensioner on it came loose.
Old 01 May 2016, 08:36 am
Thanks for the response so quick. I had to get the water pump replaced so had a Mopar shop do that and also the timing belt since it's a pain in the butt to have to take everything apart again for the belt at a later date. I get a code p0340, as well as a p0303, and also p1684 as well.
Old 01 May 2016, 08:54 am
But did you CHECK it? That's the question here, not who did it. The 1684 indicates that the TCM has been disconnected or may have a bad connection. Did you disconnect it? The 0340 indicates the Cam Sensor. Have you monkeyed around with it? Disconnect it and see if the car will start. The 0303 is a misfire code for cylinder 3. Could be anything from a fouled plug or wire to an EGR problem. Check the frigging timing belt first. Don't start shot gunning parts at it or you'll never figure it out.
Old 01 May 2016, 09:31 am
P0340 - No Camshaft Position Sensor Circuit Failure Conditions:
Possible Causes:
Camshaft Sensor connector is damaged, open or it is shorted
Camshaft Sensor signal circuit is open or shorted to ground or to battery voltage or 5 volt supply circuit
Camshaft Sensor 5 volt supply circuit is open or shorted to ground or to battery voltage Sensor ground circuit is open
Camshaft Sensor is damaged or has failed
Crankshaft Sensor is damaged or has failed
PCM has failed
I would suggest diagnosing the P0340 code. Its always good practice to put the original parts back into the PT Cruiser if they don't fix the problem. You might be making it worse if the new parts are not working properly.
There is a clip that holds the wiring harness up to the block going to the crankshaft sensor that breaks and the wiring harness drops down to the half shaft and start rubbing through it shorting wires out. Make sure you check this out as this is a common problem for your year PT Cruiser.
If the wiring harness is okay I would suggest pulling the camshaft sensor and see if the camshaft is turning when you crank the engine. The camshaft sensor is very easy to remove and when you re-install it be careful not to over tighten it. I am aware that the engine is getting spark but this is just to verify the camshaft is turning continuously. This should only take ten minutes.
If the camshaft is turning and you have checked the camshaft sensor, wiring going to the camshaft sensor I would suggest checking the crankshaft sensor and the wiring going to the crankshaft sensor.
Old 01 May 2016, 09:38 am
Possible Causes:
PCM has failed
If the camshaft is turning and you have checked the camshaft sensor, wiring going to the camshaft sensor I would suggest checking the crankshaft sensor and the wiring going to the cranshaft sensor.
I did check the sensor and actually replaced it. I also did check the camshaft and they did turn. I also changed the coIL as well as the egr valve.
Old 01 May 2016, 09:42 am
Yes I checked it. Everything is tight and seems to be moving properly. The tensioner also seems to be ok as that is tight. I replaced the camshaft sensor yesterday as well as the ignition coil.
Old 01 May 2016, 09:45 am
Possible Causes:
PCM has failed
I did check the camshaft sensor yesterday and the cams are turning. But decided to replace the sensor just to make sure. I will try the crankshaft sensor next. Thank you
Old 01 May 2016, 09:50 am
Check the wiring harness going to the crankshaft sensor also.
Compression VS Compression Ratio scatgo1 Tech & Performance Forum 2 18 Oct 2015 08:19 pm
Very Low Compression '02 2.4L engine mojodec Tech & Performance Forum 40 29 Aug 2015 02:43 pm
The no compression engine PTProblems Tech & Performance Forum 2 01 Apr 2011 09:15 pm
timing belt/ no start/ no compression sylster General Turbo Discussions 8 01 Mar 2010 08:42 pm
engine low on compression LoWandSloW Tech & Performance Forum 7 02 Jul 2007 09:58 am
