unusual tensioner question, with video
Old 01 May 2016, 10:09 am
Default unusual tensioner question, with video
04 I put the tang in the arm notch, tighten the bolt, and the setting notch can't turn to align with the tang. Here's a quick video: https://youtu.be/PZiwabsItzw
Old 01 May 2016, 01:38 pm
Default Re: unusual tensioner question, with video
Must be missing some spacer, did you compare it to the one you removed?
Old 01 May 2016, 10:33 pm
I can't figure out how the tensioner works? I turned the inner part after semi bolting it on, and the setting notch is now below the notch on the arm. Should I install the timing belt? And then just crank the allen wrench, that would move the setting notch enough to where I could tighten the bolt, setting the belt?
I watched a video of 7 parts how to install a pt timing belt, this was shown during the 6th part at the end, 5:30, https://youtu.be/msat8GMAyso
I have put it on before, the tensioner doesn't torque, did I have it mis-aligned to start, and so the metal notches were in conflict? Should I just try try again?
Old 02 May 2016, 06:51 am
I haven't done this, so don't take my word for it. It looks to me like you need to just snug the center bolt on the tensioner, and then use your 1/4" drive ratchet to rotate the inner portion of it clockwise until the spring contacts the deep notch. Then, rotate the engine crank two revolutions, check your marks and make the final adjustment. BUT, like I said, I've not done one of these and am NOT an ASE certified mechanic. I'm not even a mechanic.
Timing tensioner bracket question glassbuggy Tech & Performance Forum 1 02 Oct 2014 06:55 pm
Unusual or no? Crid Tech & Performance Forum 11 11 Jul 2014 12:26 pm
Engine Rebuild - Timing Belt Tensioner Question tdf Tech & Performance Forum 5 15 Dec 2013 10:32 pm
timing belt tensioner question!!!! HELP!! slimjonesy General PT Cruiser Discussions 5 08 Apr 2011 08:59 am
Timing belt tensioner question - 04 PT 2.4L matt Tech & Performance Forum 0 29 Mar 2011 05:12 pm
