no crank no start
Like Tree2Likes
Old 02 May 2016, 09:52 am
Default no crank no start
Hi guys, I am having trouble with the girlfriends 09 na pt cruiser. It is a no crank no start issue. At this point I have checked all my fuses with a multimeter and all check ok. I have swapped the two relays on the drivers side cowl next to the pcm and still the same thing. All that I am getting is a click from the starter relay on the drivers side cowl. I never get power down to the small signal wire on the starter itself. Battery is brand new and fully charged at 12.3v. Only Dtc's are small evap codes. Also checked the ground strap on the drivers fender well. Cleaned some corrosion on both ends. The strap has stress cracks but I did not see any corrosion built up inside the strap. Debating on changing out this strap to a heavier duty gauge just as precautionary. Looking for my next step in diagnoses here tsb's, recalls, tips, etc. Any help or advice is definitely appreciated.
Old 02 May 2016, 10:28 am
Default Re: no crank no start
Is the little red security light on on the dash?
Is your engine light on? If so what are the engine trouble codes?
Are you using the same ignition key?
Old 02 May 2016, 10:39 am
The security light turns off a few seconds after turning the key forward and I have used 2 different keys. The dtcs I have are for a small evap leak and gas cap loose. Basically just emissions codes that have been on for a while.
Old 02 May 2016, 11:01 am
Is the security light on when you are trying to start the engine?
Are you using an OBDII Scan Tool to check for codes?
Old 02 May 2016, 11:28 am
Yes I am using an obd 2 scan reader. The codes are evap emissions leak small and loose gas cap. The security light is not on.
Old 02 May 2016, 01:12 pm
Are you getting 12 volts from the ignition switch to the starter relay?
Old 02 May 2016, 01:38 pm
When I was trying to get a reading it was very inconsistent. But I wasn't sure which terminal to test. A little rusty on my electrical.
Old 02 May 2016, 07:54 pm
My 06 was doing the same thing. Sometime the security light would stay on sometimes not.
There was a tsb from chrysler on no crank no start to do with the skim module (little red light)
If I held the key to the crank position it would momentarily hit the starter but never more.
]Turned out to be PCM was fried. I bought a three piece combo of the PCM-Key FOB- skim module. It started right up. Probably need to send it to Syked to change VIN.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 03 May 2016, 12:43 am
Check the starter relay cavity for proper output. Check to see if Pins 4 and 5 has 12 volts with the ignition in the start position.
Old 03 May 2016, 01:00 am
Make : CHRYSLER Model : PT CRUISER Year : 2008
Manufacturer : CHRYSLER LLC
Service Bulletin Number : 08-007-08 Date of Bulletin : MAR 04, 2008
NHTSA Item Number : 10024966
Component : ENGINE AND ENGINE COOLING:ENGINE
Summary :
NO ENGINE CRANK OR NO ENGINE START DUE TO ELECTRONIC LOCKUP OF THE WCM/SKREEM. *NJ
Look on the driver's side door and post what the manufacture date of your PT Cruiser is.
No crank no start, Chrysler vehicles - Ricks Free Auto Repair Advice Ricks Free Auto Repair Advice | Automotive Repair Tips and How-To
crank no start conrad PT Cruiser Videos 8 20 Sep 2016 02:34 pm
Crank no start on 02 PT Cbdani2 Tech & Performance Forum 10 26 Aug 2014 03:31 pm
crank no start 69charger General PT Cruiser Discussions 1 13 Sep 2013 08:17 am
03 crank no start. spike General PT Cruiser Discussions 3 19 Jan 2012 08:44 am
