Vibration when the car is stopped
Like Tree5Likes
Old 04 May 2016, 04:36 pm
Default Vibration when the car is stopped
I am about to buy a PT cruiser Turbo 2.4. I was doing the test drive and I notice a small vibration in the dashboard when I stopped at the light. I asked about the vibration and the person said it is was normal in PT cruisers.
Could you please give me an advice ?
Old 04 May 2016, 05:12 pm
Default Re: Vibration when the car is stopped
It's not normal. You didn't mention the mileage or year but a good guess is that it needs one or more of the motor mounts replaced.
BTW: Welcome to the forum.
Old 04 May 2016, 05:49 pm
It is a 2006 with 52000 miles. The car looks pretty new
https://sandiego.craigslist.org/csd/cto/5569897733.html
So the guy is asking asking almot 5000 bucks but if I need to change the mounts I do not have idea how much I will pay for. Any idea ?
Many thanks.. I am glad being part of this forum as well.
Old 04 May 2016, 06:25 pm
Cost is hard to estimate. If your talking a dealer or mechanic doing the work, a lot depends on the hourly rate. The parts aren't expensive. With that low in mileage, it's possible it's only the upper or lower torque strut, maybe 1 1/2 hours each but the first thing is to find a good mechanic at a garage or shop that's had some experience with PT Cruisers and find out exactly what the problem is. Remember, it was only a guess that it was one or more of the mounts.
Normally, it it had more miles, the timing belt could have been replaced and one of the signs that it wasn't done right (tooth off) is a ruff idle but I doubt that job has been done with your car.
Old 04 May 2016, 07:49 pm
I would suggest you have a qualified mechanic take a look at the PT Cruiser. You might find something that might be a major repair.
Old 05 May 2016, 11:02 pm
soonercruiser's Avatar
Cool Re: Vibration when the car is stopped
I agree with this.
But, the shaking is like torque struts (aka motor mounts).
You will probably also get a little front end "clunk" when placed in gear, or hit the gas hard.
Frank, aka SOONERCRUISER,
2011 GWE Dodge Challenger SRT8 as Show Car
Old 05 May 2016, 11:56 pm
Vibration is not normal as my 06 115,000 miles idles so smooth at red lights
I wonder if its still running.
Try it with the AC in the off position and see what happens.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 06 May 2016, 03:02 pm
I checked with the mechanic. He said that I have two mounts that must be replaced but even after the replacement I still see the vibration.
However, you are right !!! if the AC is off, there is NO vibration !!!! What should I do ?
Old 06 May 2016, 03:31 pm
Your radiator fan might not be working properly. You need to check and make sure its working properly to ensure your engine does not overheat and your A/C works properly.
CREWZIN and JoeX like this.
Old 08 May 2016, 12:52 pm
The radiator works fine and the car is not over heating. The mounts were changed but I still have a vibration with A/C on. I do not know what to do.
Tags
dashboard, idle, low rpm, vibration
Stopped for a red light......... tazszzzzzz Welcome New PT Cruiser Members 14 11 Mar 2013 01:10 pm
Now what? Sputtering stopped mahgninnuc68 Tech & Performance Forum 7 15 Feb 2012 08:13 pm
05 PT just stopped.... brecie Tech & Performance Forum 2 19 Dec 2011 04:08 pm
key fob stopped working twotone General PT Cruiser Discussions 10 17 Jun 2011 05:47 pm
Sub Stopped CHROMEDCRUISER Sound and Security Forum 6 10 Feb 2005 04:46 pm
