Front Suspension arm rubber bush
  • 1 Post By rcktpwrd
Old 07 May 2016, 05:17 pm
whiteclaw's Avatar
Default Front Suspension arm rubber bush
Any good brands for these or certain type, different type of material?
I appear to be replacing mine every year going with OE ones.
Chrysler PT Cruiser 2001, Automatic, No Mods, Right hand drive. 2.0
Old 07 May 2016, 05:31 pm
Default Re: Front Suspension arm rubber bush
Kind of a vague question since there are several bushings to choose from. Are you referring to the sway bar bushings, control arm bushings or maybe even the sway bar end links. We need more info, man.
Old 07 May 2016, 06:28 pm
rcktpwrd's Avatar
have you tried polyurethane?
I have the complete Energy Suspension kit in my car and like it, the black bushings. Some have used the Prothane brand with good results as well.
Danny7627 likes this.
Joel
www.rcktpwrd.com
Old 07 May 2016, 08:16 pm
You most likely have a problem that is causing the premature wear of the bushings. I would recommend to first find out the cause before replacing another bushing.
Installing a harder bushings may cause other suspension problems or early worn parts.
Old 08 May 2016, 05:59 pm
whiteclaw's Avatar
To be honest, i am not entirely sure. this is what comes up on the MOT as needing replacing. I always took it to a garage to do who use OE parts, but it's like a yearly thing. Roads are bad here where I am though.
Squeaking Front Suspension Nvizn Wheels, Tires, Suspension 17 15 May 2014 07:42 pm
front suspension cruisercrazy Tech & Performance Forum 11 14 Feb 2013 08:43 pm
noisy front suspension namvet125 Wheels, Tires, Suspension 9 27 Mar 2012 07:54 pm
Front suspension advice classiccruiser Wheels, Tires, Suspension 12 31 May 2011 12:48 pm
front end suspension babygms2005 Wheels, Tires, Suspension 9 10 Dec 2010 08:26 pm
