Break makes noise and it makes the rim very hot!!!
Like Tree3Likes
  • 1 Post By chuzz
  • 2 Post By chuzz
Old 10 May 2016, 04:52 pm
Default Break makes noise and it makes the rim very hot!!!
Hi guys
I just changed winter tires to summer tires and after that got a huge noise problem
the noise comes from the left back tire
specially higher when turning on left or right
and when i press the break the noise disappears
i drived it for about 25 minutes to figure it out and after i stopped i touched the rim and it was extremely hot (the other 3 rims were all cool)!!!
so i took the tire out, the break was very rusty and old. so i hit it few times and put the tire back
but i didnt turned to bolts very tight just used my arm pressure (first time when i changed it i used my legs strength)
anyways then the noise disappeared !!!
but after like 15 minutes the noise come back and it was kinda lauder then before !!!
anyone of u had the same issue ???
is there an easy solution ???
do i need to change the break ??? (i dont really want to do that)
and this friday i need to drive a 4 hours trip is it dangerous to go with that situation ??? (the rim gets really hot)
and all this happened just after i changed the tire !!!
thanks for all your helps
Old 10 May 2016, 05:35 pm
Default Re: Break makes noise and it makes the rim very hot!!!
Sounds like you over torqued the rims and stretched the bolt holes on the brake drum. Lug nuts should be torqued to 100 ft lbs. You MIGHT be able to remove the brake drum and use a ball peen hammer and tap the holes down. But if they've got cracks around them, you need new ones. Who in the world ever told you to use your legs to tighten lug nuts? I'm surprised you haven't broken a lug off doing that. I can put over 200 ft lbs of torque by "legging" a bolt or nut. DON'T do that anymore. Get a torque wrench.
ptprice likes this.
Old 19 May 2016, 08:16 am
thanks for the help
I have loosened the bolts little so the sound is mostly gone sometimes comes back but for few seconds so no issue about the sound and the heat from the tire anymore.
but !!!!!!
now i got another issue.
when i turn right (only turning to right) the inside lights open and beeps (same sound when i open the door while the key is still in but engine is stopped)
I really cant figure it out !!!
any suggestion ???
is it related to the tire ???
thanks for the help again.
Old 19 May 2016, 10:57 am
Are you referring to the dome (or overhead) light? If so, it sounds like your driver side door isn't latching all the way. I'd double check the door latch if it were mine. You can make adjustments without removing anything.
Fk5 and Handy_Cruiser like this.
Old 19 May 2016, 11:29 am
Fk5 Fk5 is offline
Does it have to be the latch? In the old days we had all kinds of trouble with the pin switches being out of adjustment and the car thinking doors were open when they were closed and vice versa. I haven't had any trouble with the ones on my PT, but now that I have said that, trouble is sure to follow!
2003 GT 5 speed
162,000 miles
Old 19 May 2016, 01:11 pm
the overhead light opens for few second and the beep starts at the same time.
it only takes few seconds sometimes more than 3 seconds !!!
an i specially check the dor light when it starts to make noise but no door light !!!
i have tried to shut the door little hard but nothing changed.
it only happens when i turn right.
thanks again.
Old 19 May 2016, 04:00 pm
I'm still thinking it's the drivers door, but I'm not a mechanic. Maybe someone else can enlighten us.
Old 19 May 2016, 08:39 pm
I would suggest checking the engine oil level. Check anything that might have an effect on the PT Cruiser not being level.
Need help after a turbo was replaced and it still makes the noise mrpilat General Turbo Discussions 5 22 Jun 2012 01:31 pm
Fan makes noise? Jimmy2011 General PT Cruiser Discussions 3 17 Apr 2012 10:45 pm
What else makes grinding noise? 808 Wheels, Tires, Suspension 14 04 Apr 2012 04:21 am
My Car Makes Hissing noise when driving.. no noise from reverse or netural kasasoze Turbo Performance 3 04 Dec 2011 09:07 pm
The noise engine makes when you shut off? stirfry Tech & Performance Forum 7 26 Apr 2004 06:50 pm
