2006 ignition security bit
Old 12 May 2016, 01:59 pm
Default 2006 ignition security bit
Can anyone tell me what is the security bit needed to remove the ignition actuator and where I could buy it?
I have a new set of security bits. A T27 is too small and T30 does not quite fit. I need to know the correct bit.
Old 12 May 2016, 08:09 pm
Default Re: 2006 ignition security bit
The manual for 2006 says it takes: Tamper-proof Torx Plus (five Point) 30 bit. Obviously the TH30 I have is not quite correct as it will not fit into the bolt. I will go and find the correct bit.
Old 12 May 2016, 08:35 pm
I think I ordered mine on line at amazon. 6 piece set.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
2006 and up Ignition redesign- Key cylinder removal JoeX General PT Cruiser Discussions 18 08 Dec 2016 03:35 pm
2006 PT Cruiser Ignition Switch Actuator Pin Fryz2500 Tech & Performance Forum 0 12 Aug 2015 05:47 pm
2006 Ignition switch replacement Samson Tech & Performance Forum 12 19 May 2015 05:00 pm
2006 and newer ignition problems and possible solve(or roadblock) PTCruisn81 Tech & Performance Forum 1 11 May 2013 08:48 pm
2006 ignition shroud screw size? Samson Tech & Performance Forum 1 22 Apr 2012 10:37 pm
