2006 Shift Problem
Old 13 May 2016, 01:20 pm
Default 2006 Shift Problem
My 2006 PT Cruiser will sometimes not shift out of low gear. I can pull over and kill it and restart and it will shift normally. This morning when I attempted to start it would not turn over. After trying repeatedly it finally started. I don't know if this is related to the other problem or not!! Any suggestions!!!
Old 13 May 2016, 03:36 pm
Default Re: @006 Shift Problem
Isn't this a double post and you found a loose battery clamp?
Old 13 May 2016, 06:09 pm
Default Re: 2006 Shift Problem
Yes I inadvertently posted twice!
Old 04 Jul 2016, 02:21 am
weppler
Did you find the root cause ? I have the same problem with my PT turbo 2006.
Old 04 Jul 2016, 07:27 am
His appears to have been just a loose battery clamp. You might try cleaning and tightening yours. BOTH cables.
A BAD 2001 PT Cruiser stick shift problem! Artista General PT Cruiser Discussions 9 21 Aug 2015 10:35 pm
looked but cant seem to find automatic shift problem jT101 Southeast PT Forum 4 01 Oct 2014 03:39 pm
Check engine & gear shift problem sunny8088 Tech & Performance Forum 11 07 Nov 2012 08:35 am
06 Shift problem Ptea Tech & Performance Forum 0 18 Dec 2011 08:05 pm
Changed Shift solenoid but still wont shift hawaiian General PT Cruiser Discussions 1 19 Oct 2009 07:32 am
