Error gode p0172
Old 13 May 2016, 08:44 pm
Default Error gode p0172
Got this code when i start the car,where do i beginn, are there some scanners that will point what is wrong?,cause the car scanner does only say p0172
Old 13 May 2016, 10:11 pm
Default Re: Error gode p0172
That code means that the 02 sensor has detected that the engine is running rich. Have you ever done a tune up? New plugs, wires, air filter, PCV valve and clean the throttle body. First though, pull a plug and see if it's black. If so, that means something is causing it to run rich. If the plugs look good, then I don't know what the hell to tell you. Check the air filter, maybe.
no bus error ejm Tech & Performance Forum 2 16 Oct 2014 07:08 am
Error Codes Error lilcruiser Tech & Performance Forum 2 10 May 2012 05:34 am
error code p0172 ? bree1976 General PT Cruiser Discussions 2 02 Oct 2011 08:12 am
dtc p0172 fuel cintra07 Tech & Performance Forum 1 06 Oct 2010 11:33 am
P0172 Fuel Trim System Rich Bank 1 koutsour Tech & Performance Forum 2 17 Jul 2007 02:15 pm
