Overheat and Won't Start
  • 1 Post By JoeX
Old 15 May 2016, 07:54 am
Default Overheat and Won't Start
Sure this has been discussed at length before, but scouring all the threads is almost as much of a headache as tearing the car down. That said...
Bought a 2001 Ltd (107k/1 owner) last week that reportedly overheated about 6 months ago and was seemingly okay until a few weeks back when it died. Previous owner's (PO) shop says engine is shot. I'm not so sure.
I'm thinking something else failed since the overheat - related or not.
Engine cranks, but does not start. PO302 is the only stored code. Sounds like compression is there on at least two cylinders.
I shot some starting fluid into the TB to see if it might kick, but nada. That's as far as I've gone.
Certainly there is a logical diagnostic starting point for something like this.
I'd like to make sure it fires before I determine if it needs to be torn down.
Thoughts?
Old 15 May 2016, 08:08 am
Default Re: Overheat and Won't Start
Thoughts?
Take off the cam position sensor and see if the magnet turns, its attached to the cam, when you try to start it. If it does not turn, timing belt either lost cogs (teeth) or is broken.
Either way it was due at 90,000-100,000.
LionPT likes this.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 15 May 2016, 10:16 am
First thing I would check is the battery and cable connections. Make sure you have a battery load test done with the battery in the PT Cruiser. If your battery voltage drops below 10.5 the engine will not start.
If battery and battery connections are good I would suggest checking the wiring for the camshaft and crankshaft sensors. Sometimes when someone starts working on a PT Cruiser they will pull on the wire harness and break a clip underneath the engine holding it in place. The wire harness falls down and starts rubbing on the half shaft. Go underneath the
PT Cruiser and see if the harness wires are shorting to ground rubbing on the half shaft or the frame. This is a common problem for the 2001 & 2002 PT Cruisers.
If the wire harness looks okay I would suggest measuring the voltage going to the camshaft sensor. Post what you find.
Another A/C overheat acmectec2001 Tech & Performance Forum 2 04 Jul 2014 08:25 am
overheat issues w/air on only 03dreamcruisermn Tech & Performance Forum 4 14 Oct 2013 01:31 am
How not to fix an overheat problem!! 767skyking Tech & Performance Forum 16 07 Aug 2012 04:12 pm
Another Overheat PT PTJohn Tech & Performance Forum 4 15 Sep 2011 12:53 pm
overheat onyx pt General Turbo Discussions 11 27 Nov 2006 10:55 am
