P0218 & P0714
Old 19 May 2016, 08:03 am
Question P0218 & P0714
PT is at the dealer and found the subject stored codes and aren't sure if I should be concerned?? P0218 (Transmission High Temp Operation Activated) & P0714 (Transmission Temp. Sensor 1 intermittent) To me it seems i need a new Transmission Temp 1 sensor (or a bad wire/connection). Thoughts? As always, thanks in advance!
Old 15 Jun 2016, 06:23 pm
Default Re: P0218 & P0714
I recently had the same codes come up on my '06 PT, and also P1684 ...
Also, recently, I noticed that as I am driving at higher speeds (40+) the car seems to "jolt" forward with extra "oomph" and then sometimes it will seem that it's a bit lower on power ... However, I'm not seeing any specific jump in RPM's to account for the extra jolt/power....
Also, don't know if it'll help any one in the future... but I believe my TIPM is bad, as the driver low-beam headlight has been disabled and also the low-speed of my radiator fan has either been disabled or has malfunctioned in some manner.
Error codes P1684/P1603/P0714/P0218 chaoscow Tech & Performance Forum 14 31 Oct 2014 12:24 pm
