Check engine light
  • 1 Post By ptcruisersteve
Old 24 May 2016, 11:31 am
Default Check engine light
I recently had my check engine light checked and was informed I had a miss on #2 cylinder. I replaced the wires and plugs Now the guy at Autozone says there are some old codes that he can't clear. I tried taking the battery cable off but the engine light comes back on......any suggestions???
Old 24 May 2016, 11:45 am
Default Re: Check engine light
Removing the battery cable only resets the DTC warning. DTCs are stored in the PCM even if the battery is disconnected and will remain in fault until that condition is no longer present.
Unless their is a problem with the diagnostic connector or the PCM you can clear DTCs with a good scan tool.
Try going to a different place to get your DTC read and cleared.
FYI in the future if you get a DTC you should note what it is clear it and then see if it returns before assuming anything and randomly replacing parts.
Old 24 May 2016, 12:28 pm
I prefer to have my own OBDII Scan Tool instead of relying on someone else that might have a bad scan tool or not be trained properly on how to use a scan tool. The OBDII Scan Tools are not that expensive and you save time not having to take it somewhere.
This is where I got my OBDII Scan Tool.
Search results for: 'OBDII scan tool'
NitroPT likes this.
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
check engine light edscrz General PT Cruiser Discussions 5 01 Dec 2013 08:35 pm
Check engine light and battery light on tay2208 Tech & Performance Forum 2 27 Jul 2011 05:44 am
Dashboard goes crazy, check engine light,oil light...... jggarza3247 Tech & Performance Forum 2 10 Jul 2011 06:23 am
Check engine light: Amber Light: power loss dbleclk Turbo Performance 2 06 Jul 2011 06:12 am
