shift lever hard to move
Like Tree7Likes
Old 02 Jun 2016, 08:27 pm
Default shift lever hard to move
When my 08 PT gets thoroughly warmed up on a hot day, the auto trans shift lever becomes hard to move between PRND. This seems to have started happening after a trans fluid and filter change. The level on the trans dipstick is above the 2nd HOT mark when the vehicle has warmed up.
Just wondering if perhaps the trans is overfilled and this is somehow causing the stiff lever. Shifter moves smoothly with vehicle cold.
Old 02 Jun 2016, 09:05 pm
Default Re: shift lever hard to move
First, did you make sure that the correct ATF+4 fluid was used?
Second: Can Too Much Transmission Fluid Hurt a Vehicle? | DoItYourself.com
Old 03 Jun 2016, 03:42 am
trans has always been filled with ATF+4
my guess is that trans may be slightly overfilled... my plan is to drain some of the fluid and see if shift lever frees up when hot, hopefully this clears up the problem, otherwise it's something else
will report back with results
Old 03 Jun 2016, 07:59 am
rsrocket1's Avatar
Default Recommendation
If you don't have an aftermarket pan with a drain plug, this pump works great for partially removing some ATF. The included orange hose fits down the PT Cruiser ATF dipstick tube and you can pump some of the ATF out if overfilled. A handy tool for $7
Old 03 Jun 2016, 11:52 am
Default Re: Recommendation
rocket
have that pump, have used it to transfer diff fluid... works great
have an aftermarket pan w/ drain on the PT, Dorman p/n 265-801
cruserdad1976 likes this.
Old 03 Jun 2016, 11:55 am
rsrocket1's Avatar
Yes, I put in an ATF pan with a plug also. Very good upgrade.
Old 03 Jun 2016, 12:42 pm
Fk5 Fk5 is offline
Even with the drain plug, a pump might be the preferable way to remove a small amount of fluid.
2003 GT 5 speed
162,000 miles
Old 16 Jun 2016, 06:19 pm
UPDATE
Auto trans was slightly overfilled. Drained 1/2 qt of excess ATF+4. However, this did not seem to make any difference with the "stiff shift lever when vehicle is hot" problem mentioned in my OP. Oh well...
Old 16 Jun 2016, 06:32 pm
Check the shift bushings. One may be cracked and hanging slightly.
Old 22 Jun 2016, 06:06 pm
UPDATE
Checked the cable from the shifter to the transmission. Found that it passes close above the catalytic converter. There is a short length of foil covered tubing that is placed over the shift cable but it is positioned forward of where the cable passes over the cat. If it was placed there to protect the shift cable from heat from the cat then it either has slid forward or was not installed correctly in the first place. It is doing no good and serves no purpose in its present location.
Anyway, found a short piece of high temp hose in the garage. Slit it and placed it over the shift cable above the cat. Let's see if this cures the stiff shifter when hot issue mentioned in my OP.
Stay tuned... will update.
Hard to move shifter automatic L2fish Tech & Performance Forum 21 17 Jan 2015 09:19 am
Hard Down shift? red98gt Tech & Performance Forum 0 07 Aug 2014 03:57 pm
Hard to move between gears 2005 covertible droptopman PT Cruiser Convertible Forum 4 23 Oct 2012 02:46 pm
Hard to shift into reverse opelenvy Tech & Performance Forum 5 28 Jun 2007 09:55 pm
Looking for company that modifies shift lever Cal Cruzer General Turbo Discussions 0 05 Apr 2004 04:38 pm
