New engine and No crank
Old 08 Jun 2016, 03:34 pm
Angry New engine and No crank
So I have a '06 Pt Cruiser that needs help getting to start.
The previous engine overheated and blew the head gasket and sat for a year. I just recently ordered an engine from LKQ with 85k miles with complete harness attached. I took the old engine out and put the newer engine in and it wont crank.
Everything is where it should be and plugged in. I put the key in ignition and I get a click from the starter. The battery in new and the starter has been bench tested at a local auto parts store and passes all the test twice.
kind of lost of what can be causing the starter to just click and not kick the engine over.
Old 08 Jun 2016, 03:58 pm
VsandFords's Avatar
Default Re: New engine and No crank
If the engine is free, meaning you are able to manually turn the crank, I would check all of the connections between the battery, starter and ground. This is to be sure that you are getting proper voltage and amps needed to turn the engine.
Old 08 Jun 2016, 04:04 pm
Did you get an extra starter with the new engine? If you're getting it tested at Autozone, you're just wasting your time. I'd check all of the ground cables and straps first and if all are clean and tight, check the positive cable too. Check the connections to the starter. If you left one loose, that'll do it.
Old 08 Jun 2016, 04:36 pm
All grounds and power staps have been looked over and seem to be in place.
Side note the engine isn't turning over by hand when installed. It did out of car.
My suspicion, could the torque converter be messed up. I pulled just the engine when replacing it. The install went smooth but when turning the flex plate to put the bolts into the converter we noticed that it would turn easiest when at least two trans bolts where loosened.
What could be wrong with the torque converter that isnt maybe allowing the starter to kick everything over?
Maybe when the trans is being fully seated to the engine it is binding too much? What are some issue that could be run into with the torque converter?
never had an issue like this before.
Old 08 Jun 2016, 05:13 pm
Most members have found the starter to be the problem. Auto parts store does not test the starter under a load.
Is the starter from the original engine or from the new purchased engine?
What voltage are you getting from the ignition switch to the solenoid?
Old 08 Jun 2016, 05:16 pm
Tourk converter came out of trans and now pump drive tanges are not in to pump right
Old 08 Jun 2016, 05:21 pm
I'll check what the starter is getting.
Old 08 Jun 2016, 06:37 pm
VsandFords's Avatar
What he is saying is the torque converter has to be seated into the trans correctly. If not, it will be in a bind went you bolt the engine to the bell housing.
Old 09 Jun 2016, 07:40 am
Handy_Cruiser's Avatar
Yep. I've seen this one before. It's a possibility. +1
And if this is the case it will be very difficult to manually turn the engine from the front crank bolt. Check that first. And if you find it hard to turn the engine, and if you can pull the engine oil pan and get to the torque converter bolts, then remove them. The torque should be able to slide back about a quarter inch and spin freely. If it's bound against the flex plate, then this well may be the issue.
Also, did you check to see if the engine would turn freely before installing it. There's always a chance the engine you got from LKQ was locked up when you got.
Old 09 Jun 2016, 08:06 am
Stupid question, but I like asking them. Did the engine come out of another automatic PT or a manual shift? If not another automatic, then the hole in the end of the crankshaft isn't big enough to accept the torque converter "knob". It's not big enough and would need to be expanded.
05 PT won't crank aps703 Tech & Performance Forum 4 16 Nov 2015 07:56 pm
No Crank clindley Welcome New PT Cruiser Members 2 09 Jun 2015 09:46 pm
no crank clffkirts Tech & Performance Forum 1 03 Jun 2015 08:46 pm
PT Cruiser engine won't crank scoobybug Tech & Performance Forum 7 24 Jun 2014 07:53 am
2007 PT cruiser died, parts replaced, engine codes are gone, but car wont even crank andrewsmith1984 Tech & Performance Forum 9 30 Dec 2012 10:44 pm
