Brake Fluid ?
  • 1 Post By chuzz
Old 09 Jun 2016, 07:39 pm
Default Brake Fluid ?
Need to just top off my brake fluid. Can I use 'Dot 3' high temp synthetic ?
Thanks!
Old 09 Jun 2016, 08:07 pm
DroptopPTGTCruizer's Avatar
Default Re: Brake Fluid ?
I have researched this very topic in the not so distant past, found that all DOT 3 brake fluid is synthetic, and a version stating "high temp dot 3" is compatible with all Dot 3 brake fluids. A google search will turn up a couple threads on "oil specific" forums that discuss at exhaustive length if interested in a long through read about it.
2005 PT GT Convertible HO Turbo Autostick ~ black/black leather ~ 53,000 miles ~ summer-only driver ~ OEM rear sway bar ~ K&N 57 series CAI ~ 4-wheel ABS ~ Hawk Sector 27 drilled/slotted rotors ~ Hawk Performance Ceramic pads ~ Firestone Firehawk Indy 500 Wide-Oval performance tires ~
Old 09 Jun 2016, 08:08 pm
Handy_Cruiser's Avatar
Thanks!
I think is says right there on top of the cap. I pretty sure it's just DOT 3. Both mine were.
Old 10 Jun 2016, 07:42 am
Why is yours low? That's the first question you need to be asking. Check under the car on the back of your wheels. Maybe a brake hose or caliper/wheel cylinder leaking.
Handy_Cruiser likes this.
Old 10 Jun 2016, 01:16 pm
Thanks!
Make sure it also meets MS-4574.
Old 10 Jun 2016, 02:19 pm
As you are checking your brake lines, i would also check the condition of your pads. As they wear, the pistons are extened more "consuming" the fluid from the resevoir.
Hissing near brake fluid reservoir ptkwt General PT Cruiser Discussions 5 09 Jul 2014 04:09 pm
New here and brake fluid loss question ojay Tech & Performance Forum 7 03 Jun 2014 01:10 am
Brake Fluid interval discovering06 Tech & Performance Forum 2 10 Jul 2013 01:01 pm
flushing brake fluid bugatti Tech & Performance Forum 18 26 Mar 2011 12:27 pm
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
