It's running again but.
  • 1 Post By ptcruisersteve
Old 12 Jun 2016, 12:24 pm
Exclamation It's running again but.
I just replaced my 2006 automatic shifter cable the only problem is the shifter knob seems very loose now in hard to really set in drive and it's got a bad miss once in a while any suggestions I also had to replace my ignition switch at the same time whew
Old 12 Jun 2016, 12:41 pm
Default Re: It's running again but.
Is your engine light on? If so what are the engine trouble codes?
I recommend only repairing one problem at a time and then verify it taken care of before repairing another problem otherwise it can be harder to diagnose.
chuzz likes this.
Old 12 Jun 2016, 12:52 pm
Sounds like you need to adjust the shift cable. Was it doing that before you replaced the cable?
Old 12 Jun 2016, 01:20 pm
No after relaceing shift cable and engine light isn't on
Old 12 Jun 2016, 06:17 pm
Then it sounds to me like you've already answered your own question. Go back and check to see if you have room for adjustment. I don't know which way to tell you to go with it, as I haven't had that problem with mine. Sorry.
Is any one running 225/45-17? chigger_ns Wheels, Tires, Suspension 8 07 Jun 2015 12:21 pm
02 Running Hot iwuvwoo Tech & Performance Forum 7 31 Jan 2014 10:03 pm
Anyone is running one of this? ROCKETMAN8060 Tech & Performance Forum 26 17 May 2012 11:06 pm
not running too well!!!! ptcruiser1988 Tech & Performance Forum 10 05 Mar 2011 08:53 pm
up and running again careyk Canada PT Forum 1 19 Feb 2008 01:31 am
