2002 PT Cruiser going through a quart/week oil and coating back of car in oil residue
Like Tree3Likes
Old 13 Jun 2016, 11:43 am
Unhappy 2002 PT Cruiser going through a quart/week oil and coating back of car in oil residue
'02 PT Cruiser going through a lot of oil and coating back of car in thick black oil residue. Please help. What could be causing this???
Old 13 Jun 2016, 03:33 pm
Default Re: 2002 PT Cruiser going through a quart/week oil and coating back of car in oil res
Fairly common for valve cover gasket to fail - is back of engine coated in oil? Get car up on ramps and look underneath.
If you take your car somewhere for oil changes, look at oil filter and drain plug for leaks.
How many miles you drive in a week?
How long has this been going on?
Old 13 Jun 2016, 03:43 pm
Welcome to the forum.
I would suggest first checking your air filter.
Old 13 Jun 2016, 04:00 pm
Check pvc valve and hose going to it
Old 13 Jun 2016, 07:16 pm
Thanks for the prompt replies guys.
It's been doing this since I bought it two years ago. I drive about 30-40 miles a day. It's got 155,000 miles. It was spitting white smoke out of exhaust when bought it I replaced pcv valve and hose. Fixed the white smoke and idle issues. I do see somewhat of an oil leak underneath but not enough for the amount of oil I go through. There is oil pretty much coating everthing under engine.
Old 13 Jun 2016, 07:17 pm
Smile Re: 2002 PT Cruiser going through a quart/week oil and coating back of car in oil res
By the way. Feeling very accomplished. I just replaced a lower control arm, sway bar link, and both outer tie rods.
rckstein and VsandFords like this.
Old 13 Jun 2016, 07:57 pm
You would be surprised how much oil you can burn with a clogged air filter.
chuzz likes this.
Old 13 Jun 2016, 10:08 pm
I agree with Steve about the air filter. You might also want to take a look at your oil sending unit or oil pressure switch, whatever name you prefer. Sometimes they can leak under pressure and piss oil all over the place.
Old 13 Jun 2016, 10:33 pm
VOS's Avatar
VOS VOS is offline
to add to the list of "checking" ... the crank sensor [O-ring]
Old 14 Jun 2016, 07:34 am
Does the car smoke at all? Oil coating the back of the car, sounds alot like you are burning oil. Might want to check the compression and look at your plugs.
Another Action Next Week,Another PT Cruiser??? randyincctx General PT Cruiser Discussions 17 20 Nov 2013 08:51 am
Where is the 5th quart of oil? briancpearce Tech & Performance Forum 20 20 Aug 2010 07:45 pm
2002 PT Cruiser Back Seats dano4193 Classifieds: For Sale/Trade 0 27 Oct 2008 07:54 pm
Wax residue infernocruisr01 General PT Cruiser Discussions 5 20 Jun 2007 08:02 am
Chrome Exhaust black residue cleaning PTskilla The Detail Shop 3 28 Apr 2004 11:40 am
