How difficult is it to replace the TIPM yourself?
Like Tree2Likes
  • 1 Post By chuzz
  • 1 Post By rckstein
Old 15 Jun 2016, 06:54 pm
HippysChick's Avatar
Default How difficult is it to replace the TIPM yourself?
Just an idle query, really.
I've had a nose at Rockauto and the A1 Cardone site, and see that a remanufactured TIPM is $400 give or take including the $130 core. The shop I take Petra to said $1,000 all in to replace it.
Hubby is a retired electronics tech and if it's a case of unplugging the old one and plugging everything back in to the new, more or less, he could probably either do it himself or walk me through it.
About to get a settlement pay out from November's accident, so we will be able to afford it soon whether we DIY it or pay the shop to. I'm just a hair leery of throwing more money at the dratted thing. Got it back yesterday with the usual news: 'It started right up when we moved it into the shop and we can't find anything wrong with it.'
https://www.facebook.com/photo.php?fbid=10151892189824122&l=627caad7f3
Previous PT Cruiser: 2007 Touring Edition (non-Turbo) in Ocean Pearl.
Current Cruiser: 2007 Limited Edition Turbo, chrome trim package, Cool Vanilla (husband's car).
Now driving a 2014 Ford Escape SE 2.0 Ecoboost, Deep Impact blue (perhaps not the best name choice for a vehicle of mine!)
Old 15 Jun 2016, 07:17 pm
Default Re: How difficult is it to replace the TIPM yourself?
From what I can tell, it should be a simple plug and play type thing. JUST BE SURE TO DISCONNECT THE BATTERY FIRST! I have zero training in electronics and I sure as hell wouldn't pay anyone $1,000 to replace something I can do myself. Look on youtube. You can find several videos of how to do it, if your hubby wants to save some money and do it himself. No big deal.
HippysChick likes this.
Old 15 Jun 2016, 07:39 pm
Oh heck, yeah! Disconnect the battery first, don't open or touch the new TIPM until you're ready to install it, make sure to wear an anti-static strap or touch a ground regularly. (I've built computer
I've built computers under his eagle eye, so I have a feeling I will be doing the grunt work with input from Yer Man Himself.
Thanks!
Old 15 Jun 2016, 07:46 pm
rckstein's Avatar
Yeah, I don't get it either how it can be $1000 to replace the TIPM
The one YouTube video I watched was for a Jeep Patriot, but the TIPM was the same. It all appeared to be plug & play, with the smaller connectors even being color coded, so how could you mix them up? I noticed that the person doing the switch out taped off the lead coming from the battery, apparently he was worried about it shorting to something. But he should have had the battery disconnected so there would be no power going through that wire. The one he purchased appeared to be from a u-pull-it, so it wasn't even new or remanufactured.
This link does appear to suggest that there is some programming needed to be done after replacement, so if a dealer visit is required, that would contribute to the overall price, and why the dealer gets $1000 for replacement.
Chrysler PT Cruiser Touring: Hello, I am replacing the tipm
If anything, if I were going to have the TIPM replaced, I would also get a new lead that goes from the battery positive terminal to the TIPM. I'm not an electrical engineer, but it appears to me that that lead is small, or not a very thick gauge, considering it suppiles all the power to the TIPM, which then powers all the other vehicle systems.
For those vehicles that are having the TIPM replaced under warranty, or recall, I would be curious to know if at the same time, if they also replace that battery lead with a larger gauge wire? And what is the actual problem with the TIPM, inferior materials used during manufacture, or a design problem?
Old 27 Jun 2016, 03:52 pm
Okay, I am in a position to replace the TIPM myself.
Saturday the (does anyone speak really good German? Maybe I'd best not swear in that language either...) car did its impression of a roadside armadillo while hubby was in the car with me. Driving along a little over 70 (honest, I have to drive like an old lady with him in the car with me), the car gave a little jerk, the needles on tacho and speedo started to drop. I kept pumping the gas pedal but nothing doing, had to haul the wheel and steer into the breakdown lane.
This time, it restarted three times, we moved another mile or two, it stopped, restarted and eventually quit.
I ran the battery flat over about two hours trying to get it to restart.
So, I am going to buy a reconditioned TIPM. BUT: will i have to have Chrysler flash the TIPM before the car will run again? Answers gratefully received!
Old 27 Jun 2016, 07:47 pm
I replace the TIPM a few years ago with one from Rock Auto because of headlight failure. No problems with TIPM since.
18 months latter car decided not to run, would not turn over using the key. I turned the key on and used a jumper from the battery to the starter and it would crank but not start. Checked all the fuses none blown.
End up replacing the PCM-SKIM- key cylinder with chipped key- with one I purchased from Ebay. Cranked and fired up, been driving it for two months.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 27 Jun 2016, 08:04 pm
Hmm.
But, did you have to get the new TIPM flashed? That was what the Chrysler tech told me over the phone.
Old 28 Jun 2016, 12:51 am
Hmm.
TIPM from Rock Auto was Plug and play.
If you buy a used TIPM from a recycle yard it may need flashed. As easy as it is to install I would try it before spending spending money at dealer for Programming.
I think the units are very susceptible to moisture and corrosion. Spraying the motor off or deep water splashing I believe is a death sentence for a TIPM
73 Charger SE
01 Sebring flip
Old 28 Jun 2016, 11:13 am
Thank you so much! I'll be buying one later on, if I can get the car to start - finally got hold of a battery charger.
My niece had a baby girl on Sunday morning, so everything has been revolving around them, and quite rightly so! I managed to get a lift over to their house and borrow their battery charger this morning.
best option for difficult to see gauges PaGTCruiser Interior Accessories Forum 30 12 Jan 2016 12:17 pm
Wheel sensor replacement - how difficult? AndyJay General PT Cruiser Discussions 3 02 Jul 2012 06:35 pm
LCA bushing replacement - difficult fit?! bobdole369 Wheels, Tires, Suspension 4 17 Sep 2011 09:50 pm
It shouldnt be this difficult Busa_Powered Wheels, Tires, Suspension 10 18 Jul 2011 02:50 am
Adding Foglites? $$ How difficult 2007 mjb457 General PT Cruiser Discussions 4 21 Aug 2008 11:54 pm
