Plzzz I need HELP with 05 cruiser turbo
Like Tree3Likes
  • 3 Post By LionPT
Old 16 Jun 2016, 12:12 am
Angry Plzzz I need HELP with 05 cruiser turbo
Some help would be greatly appreciated!
05 cruiser (turbo) bought used had it 2 weeks when it started running hot. Opened hood to add water/coolant when I discovered bottom of reservoir bucket was melted . Put a temporary bucket on so I could get home. Next morning on my way to work it ran hot again then died. Had it towed to friends garage. $1850. It cost me for "new engine". Pick it up and on my way home I smell that sweet funk again ! Get home an opened the hood to see a tiny hole on the side of the tank (bucket) and it sits so close to the engine that its starting to melt . I know NOTHING about engines but this "turbo" gets extremely hot and quick. I feel somethings just not right like a maybe a fan not coming on I don't know but so paranoid I'm gonna blow the engine up that I'm checking the coolant/water every single time I get in it. Help plz . Any suggestions?
Old 16 Jun 2016, 08:48 am
Default Re: Plzzz I need HELP with 05 cruiser turbo
Find a new mechanic to take it to.
Old 16 Jun 2016, 09:25 am
Is the engine temperature going up past half way? If it is stop driving it until you find out what is causing it to overheat.
Was the new engine from a junkyard?
I would take it back to the mechanic that replaced the engine if it is a short distance away and see what they say. Post what you find out.
Old 16 Jun 2016, 10:50 am
LionPT's Avatar
Sounds like your heat shield might be missing.
Old 17 Jun 2016, 01:36 pm
Ive thought it must be missing some type of shield! There is nothing there the coolant tank sits almost on top of the engine man. I wonder if this shield came with this car originally and how much to find a replacement. I've served for pictures but couldn't find one close enough to see. THANK YOU,!
Old 17 Jun 2016, 05:11 pm
The turbo reservoir should also have a heat shield on it. It's not hard metal and doesn't cover the whole bottle, but it should be there. Mine tore away from the tabs that hold it in place, but I re-secured it with a couple of zip ties.
2003 pt cruiser 2.4l Turbo came without turbo subclassic General Turbo Discussions 26 14 Jun 2016 12:57 pm
Need help! '05 2.4 non-turbo pt cruiser Cruisista Tech & Performance Forum 13 24 Jun 2012 07:17 pm
plzzz helppp urgent !!! plz plzz pcarcamo Tech & Performance Forum 1 15 Oct 2011 06:29 pm
Colima Pro Street Shadow Turbo VS PT Cruiser Turbo skylight PT Cruiser Videos 5 31 Dec 2008 03:21 pm
Turbo on non-turbo cruiser 04VanillaCruiser General Turbo Discussions 7 02 Aug 2005 07:59 am
