AC Insulation ?
  • 1 Post By NitroPT
Old 16 Jun 2016, 07:18 pm
Default AC Insulation ?
Ok, the temp is getting hot, and I can only imagine what the temp is under the hood. Since the AC lines run very cold, do you think it would be beneficial to put pipe insulation around the lines?
Old 16 Jun 2016, 08:08 pm
Default Re: AC Insulation ?
Nobody else needs it. Can't be any hotter than it is in my neck of the woods right now. Heat index with humility making it feel like 100F and the A/C works fine.
Old 16 Jun 2016, 11:43 pm
Look up how AC works on a vehicle and you will answer your own question.
But the simple answer is NO do not wrap your AC lines.
chuzz likes this.
Old 20 Jun 2016, 08:52 pm
I thought it might be a good idea. I thought to use that round, hollow ,grey foam. What problems would I cause?
Old 20 Jun 2016, 10:32 pm
^^^^^ Higher ventilation temperatures in your AC. This leads to unforgettable driving condition and irritability.
Street Logic has one believe that wrapping AC components will help lower the air temperatures in the passenger compartment .
Old 21 Jun 2016, 04:22 pm
I guess if it was a good idea, Chrysler would have doe it.
Old 21 Jun 2016, 04:26 pm
I dont know about that comment?
I would have said if Chrysler knew something would cost them more they would not have done it and found a way to eliminate it?
Under Hood Insulation Crapped Out. PTJunkie General PT Cruiser Discussions 19 24 Jan 2015 02:55 pm
hood silencer/insulation pad bfwilson2000 Tech & Performance Forum 3 30 Sep 2013 08:58 pm
Under Hood Insulation mr.troy Classifieds: Want To Buy 0 11 Jan 2007 12:28 pm
under hood insulation cruiser12 General PT Cruiser Discussions 11 09 Feb 2005 05:07 pm
sound insulation ote69 General Turbo Discussions 0 14 May 2003 06:31 pm
