Can I remove a/c condensor if not using a/c?
Old 20 Jun 2016, 10:50 am
Default Can I remove a/c condensor if not using a/c?
I have some kind of over-heating problem with my 2005 Cruiser. Have replaced radiator cap, thermostat, radiator fan on Mechanic's advice (including dealer mechanic) Still overheats. I'm thinking that if I remove the a/c consensor, and leave it off (since im not using a/c system) that it might help to solve the over-heating problem.
Can I operate the car without the a/c condenser attached?
Any thoughts?
Old 20 Jun 2016, 11:12 am
Default Re: Can I remove a/c condensor if not using a/c?
Are you losing coolant? Has the system been pressure tested? Not normal for a PT to overheat assuming everything is fine so you need to find out what is not fine.
Old 20 Jun 2016, 11:38 am
Fk5 Fk5 is offline
I don't see why you need it if you "never use your A/C" but I doubt it will solve your problem. There has to be something wrong with your car beyond the condenser blocking your rad. I have driven my PT with a leaking radiator and some sketchy part time fixes and it doesn't run hot. If it has coolant and the fan is working, you should start looking at other potential problems.
2003 GT 5 speed
162,000 miles
Old 20 Jun 2016, 12:15 pm
If you're not running your A/C (and, remember, if you are set to defrost - selector set to windshield picture - the A/C will come on) then why do you think removing the condensor will help with overheating?
Old 20 Jun 2016, 01:05 pm
Can you drive down the road at 50 mph with out it overheating?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 20 Jun 2016, 01:56 pm
Could be a gunked up water jacket, might need a good power flush of the engine block. Hopefully, your water pump is optimally operational.
Old 20 Jun 2016, 05:10 pm
RVC RVC is offline
Another issue may be that one day down the road you may want/need to sell the car and having the condenser gone would not be a good selling point. Or you may find the real problem, fix it, and then discover that the A/C isn't so bad after all and you would have to go through all the hassle and cost of putting it back in.
For what it's worth.
RVC
2002 2.4L Woody Normally aspirated
Purchased 2/29/16 w/ 104,048 miles
where is the ECU and how do i remove it? lv42day General PT Cruiser Discussions 18 05 Oct 2014 07:52 pm
Brand new AC Condensor and Timing belt kit for 2001-2003 Cruiser myckee Classifieds: For Sale/Trade 2 03 Sep 2014 09:05 pm
How To Remove Front Seats & Remove Or Add Drawer Dill Interior Accessories Forum 20 16 Jul 2014 09:38 am
2005 PT CRUISER CONVERTIBLE - NEED RADIATOR, AC CONDENSOR AND INTERCOOLER RCFreeman Classifieds: Want To Buy 1 22 Aug 2013 10:19 pm
Condensor mounting bolt. Krueger86 Tech & Performance Forum 0 15 May 2011 06:22 pm
