pt wont start after running around
Like Tree2Likes
Old 22 Jun 2016, 09:28 am
Default pt wont start after running around
Hi all,
This is my first post, I have a 2006 pt cruiser touring edition, I can crank it up first thing drive it awhile but when i shut it off and try to crank it, it wont start, after i let it sit for a couple hrs it will start back up, on a couple of the times i noticed smoke when i first started up the car but cant see where it is coming from, i checked the oil not milky, new plugs new wires, any ideas?
Old 22 Jun 2016, 09:58 am
Default Re: pt wont start after running around
You need to run the codes on it, then post them here. If you don't have an OBDII scanner, take it to your closest autozone, advance or o'reilly. They ALL run the codes for you as a free service.
Old 22 Jun 2016, 10:25 am
i will do that as soon as i get home from work
Old 24 Jun 2016, 10:38 am
Ok finally had time to hookup the OBD II it showed 0 codes but the light was yellow and the C EV O OH were flashing
Old 24 Jun 2016, 11:06 am
How many miles on the PT?
Hammer: Take a small hammer with you next time and if it doesn't want to crank, tap a few times on the starter, A brush could be hanging up when hot and then touch the armature when it cools down and start, that little bump with a hammer might just might let it hit the armature and you will have found your problem.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 24 Jun 2016, 12:19 pm
Thank you i will give that a try, also want to ask if anybody thinks this might be a blown head gasket?
Old 24 Jun 2016, 12:33 pm
LionPT's Avatar
C - Catalyst
EV - Evaporative System
O - Oxygen Sensor
OH – Oxygen Sensor Heater
No, I wouldn't think so. All the things you posted above are air/exhaust & fuel related.
Old 24 Jun 2016, 12:44 pm
i ask because this is my girlfriends car and she called a couple of repair shops
and both said it was a head gasket, i didnt believe it was thats why i came on here.
Old 24 Jun 2016, 01:03 pm
Re read your first post... If it cranks but not start its not the starter, for get the hammer. Could be coil breaking down from heat. You would have to check for spark when it will not start.
Please clarify, no cranking or cranking and not starting..
73 Charger SE
01 Sebring flip
Old 24 Jun 2016, 02:42 pm
It will crank but no start
Replaced Head Gasket and wont stay running. Bearsonfire Tech & Performance Forum 6 02 May 2016 04:24 pm
2005 wont stay running hiitsme General PT Cruiser Discussions 13 29 Mar 2016 07:07 pm
Running Rough now wont start paisano General PT Cruiser Discussions 3 03 Mar 2014 03:15 am
car stopped running and wont start..... ptismakingmemad Tech & Performance Forum 10 03 May 2010 02:33 pm
03 GT Cruiser wont stay running. 03GTCruiser Tech & Performance Forum 2 23 Feb 2010 12:14 am
