01 power steering pulley alignment
Like Tree2Likes
  • 1 Post By PTloser32805
  • 1 Post By chuzz
Old 22 Jun 2016, 05:39 pm
Default 01 power steering pulley alignment
Hey guys,
The cruiser I'm just about finished with has one last issue I can hear.
After i had it all together again after a T belt change, I heard a belt noise. I noticed the belt riding half way off the power steering pully.
I retorqued the harmonic balancer on again. It might have moved a hair. Now the belt stays on the power steering a pully. But I get some noise on start up. I've read the pulleys need to be realigned. Basically just pulled flush on the shaft.
Anyone have some advise on how to do this easily? What puller do I need to use? A special one?
Lastly, I changed the tensioner wheel. There's no wrong way to,put that on right? Maybe that's pulling it off? I don't think so but figured I'd ask.
Thanks.
I have not insured the car yet. But I'm digging it. Planning to drive it from fl to ct next month.
Old 22 Jun 2016, 07:03 pm
Default Re: 01 power steering pulley alignment
You have to make sure the crank pulley/harmonic balancer is seated correctly.
HARMONIC BALANCER & CRANK SPROCKET REMOVEL AND INSTALL TOOL AND TIPS!!!!
Old 22 Jun 2016, 07:33 pm
I am certain the harmonic balancer is seated.
Old 22 Jun 2016, 09:34 pm
Did you take a reference measurement before you pulled the pulley off?
Old 22 Jun 2016, 10:29 pm
No.
I never touched the gear. Just the harmonic balancer. As I understand it. The HB can possibly by not on far enough. I think it tightens right up against the crank end. I used an electric impact to put it on. Then a phnumatic impact. Then the same impact with larger diameter hose for more power. It's on tight.
Old 27 Sep 2016, 09:40 pm
Today I worked on it.
Pulled the headlight. Progressively pulled the pulley out Antony bit at a time. Also starting the car to see if chirp was gone. Chirp never went away.
My time is valuable to me. So I went and got a brand new idler pulley assembly. Installed it. But pulled the pulley off to do it.
Having issues gettin it pressed back on. Haha
But I think I'll get a new belt again to for it to be new. I hope I can get rid of this noise.
Maybe I'll put it on the lift to see better the alignment,
Sucks. Any advise.
Old 30 Sep 2016, 07:56 pm
Finished today.
Trick was to keep the pulley from rotating to press it back on.
I got a new belt as well. Put it all together and no noise at all. I'm happy, I think it was a bad tensioner.
chuzz likes this.
Old 01 Oct 2016, 07:08 am
Happy to hear you got it fixed.
PTloser32805 likes this.
Old 22 Feb 2017, 04:07 am
Just worked all night on my 2003 pt basic, can you adjust the pulley on the power steering? Everything is so tight.
I have the half on belt on the pulley too, just replaced the idler pulley assembly and new belt. I thought it would do the trick!!! o No Such Luck.
I will try tightening the harmonic balancer to see if that helps. Need the car tomorrow. Could be a real all nighter!
Any help would be great.
Old 22 Feb 2017, 05:40 am
Well PTloser32805... You did it! I finally went out again, dropped the car down and started tightening the harmonic balancer. It must have gone 10 turns! I'm surprised it didn't come off while I was driving.
For the first time in at least 5 years, there are no squeaks or chirps, at all! Replaced the idler pulley (complete assembly) and the belt with no results, but after tightening the harmonic balancer the belt rides right in the middle of the idler pulley and is right in the grove on the power steering.
Thanks again for the help. Even my best mechanic had no idea how to fix this problem. It's nearing 1 am and I am finally going to bed.
Thanks again!!
Scott
Power steering pulley out of center 03PTMOM Tech & Performance Forum 25 03 Feb 2015 09:59 am
Power steering pulley? luckymagruder Tech & Performance Forum 5 18 Jan 2013 07:33 pm
Power steering tensioner pulley DODGETHIS Tech & Performance Forum 2 09 Apr 2012 03:22 pm
Bad:A/C & Power Steering Pulley Bluecruiser Tech & Performance Forum 0 11 May 2010 02:30 pm
Power steering pump pulley ? JGN General PT Cruiser Discussions 10 22 Aug 2004 07:49 pm
