2003 2.4 P0340 code....?
Old 24 Jun 2016, 08:09 pm
Default 2003 2.4 P0340 code....?
New to this site and fairly new to servicing Chrysler vehicles....PT has thrown a p0340 code, will start after 10 secs or so of cranking (hunting for timing). I pulled the connector off of the cam sensor and measured (key on engine off) 5V on pin 1, Ground on pin 2, and 5v on pin 3 which I understand is the signal input from the sensor. my concern is the 5v on pin 3..if the PCM is looking for a 0-5v input from the sensor??
Confused but looking forward to any input
thanks
Old 24 Jun 2016, 08:51 pm
Default Re: 2003 2.4 P0340 code....?
Welcome to the forum
Maybe this will help...
Part 1 -How to Test the Cam Sensor (Chrysler 2.0L, 2.4L)
Old 24 Jun 2016, 09:38 pm
Welcome to the forum.
P0340 - No Camshaft Position Sensor Circuit Failure Conditions:
Possible Causes:
Camshaft Position Sensor connector is damaged, open or it is shorted
Camshaft Position Sensor signal circuit is open or shorted to ground or to battery voltage or 5 volt circuit
Camshaft Position Sensor 5 volt circuit is open or shorted to ground or to battery voltage
Camshaft Position Sensor ground circuit is open
Camshaft Position Sensor is damaged or has failed
PCM has failed
You might want to check and see if the Camshaft Sensor is shorted out.
Old 26 Jun 2016, 10:14 am
So..I replaced the camshaft sensor just out of curiosity so no more p0340 code. Now I have a p0344 code so I've checked the wiring to the pcm from the connector and the ckp sensor was replaced. So I'm saying it's either the target magnet or the pcm. Don't know what else to check
Old 26 Jun 2016, 10:49 am
P0344 - Camshaft Position Sensor Circuit Intermittent Conditions
Possible Causes:
1. Wiring harness fault 5 volt supply circuit open or shorted to ground
2, Tone wheel/pulse ring is damaged or corroded
3. Camshaft Sensor has failed
4. Camshaft Sensor signal circuit is open, shorted to ground or battery voltage or 5 volt supply
5. Camshaft Sensor ground circuit is open
6. PCM has failed
Did you buy an after market Camshaft sensor?
Most of the time the target magnet is only replaced is when someone over torques the magnet when installing it.
Old 27 Jun 2016, 02:48 pm
Yeah it an autozone jewel...lol
code p0340 Ellenlyle Europe PT Forum 2 27 Jan 2014 06:31 pm
02 pt with p0340 code webstertroy General PT Cruiser Discussions 11 19 Jan 2013 09:26 pm
P0340 Error code on 2003 PT Cruiser Berthold Tech & Performance Forum 1 06 Sep 2012 06:02 pm
Code P0340 flcruiser General PT Cruiser Discussions 1 24 Aug 2012 07:08 pm
P0340 Code DragonBuddha06 Tech & Performance Forum 3 13 Sep 2011 09:06 pm
