2006 PT Cruiser parts/labor estimate from mechanic
  • 1 Post By ptcruisersteve
Old 27 Jun 2016, 10:54 pm
Default 2006 PT Cruiser parts/labor estimate from mechanic
(98,000 miles) I'm trying to figure out if the estimate my mechanic gave me is reasonable. Knowing nothing about car engines, I'm in that dreaded position of not knowing if my car needs these repairs and if so, am I getting a reasonable quote. Here's the list:
Two motor mounts - one top and one bottom both on passenger side
parts/labor $446
Water pump leak
Thermostat Housing leak
Timing Belt
parts/labor $620
My AC isn't working so I asked him to give me a price for that as well. He said it didn't have any freon so he would first try adding freon to see if that is the problem
Add Freon
parts/labor $115
Altogether this is more than I can afford so I'm trying to decide if I should just sell her as is or start fixing her up - one thing at a time.
Old 27 Jun 2016, 11:28 pm
rckstein's Avatar
Default Re: 2006 PT Cruiser parts/labor estimate from mechanic
parts/labor $446
Water pump leak
Timing Belt
parts/labor $620
Add Freon
parts/labor $115
Welcome to the forum
As a combined job for the timing belt and motor mount work, $1066, is about on the low end of what a dealership would charge, anywhere from $1000-$1500 is typical. What you should consider in the total job would be to replace: timing belt, water pump, tensioner, idler pulley, (2) cam seals, crank seal, center motor mount. These addtional parts would raise your overall repair a little for the parts, not much addtional for labor since the area will already be torn apart.
The thermostat housing leak the tech might have to remove the upper plenum, if that's the case, it might be wise to have the thermostat and radiator hoses replaced, especially the top one since the plenum will be off and allow easy access.
Are you the original owner and you know the service history from the beginning?
Old 27 Jun 2016, 11:46 pm
parts/labor $446
Water pump leak
Timing Belt
parts/labor $620
I would suggest going back and asking for an estimate with all of this combined. To me the estimate would be lower in labor costs.
917K likes this.
Old 28 Jun 2016, 05:20 am
917K's Avatar
I agree. The quote for the timing belt job is actually very cheap (compared to a dealership), assuming they're replacing ALL the accessory components as well as the belt and water pump, using a quality kit or OEM parts. Replacing the mounts involves the same labour of disassembly as replacing the timing system, so their quote should go down to reflect that.
Most people seem to have it replaced around 92k miles. Rubbers deteriorate with age too, so mileage isn't the only thing. The PT Cruiser uses a non interference engine, critical damage from a failed belt is uncommon, but still possible. If your car is older than 10 years or is driven daily, I think it would be prudent to get it done
Old 28 Jun 2016, 09:05 am
rckstein's Avatar
If anything, the quote for the mount work may go down, because the torque struts have to be removed anyway to do the other work, so that would be just the new parts required. But then the quote for the timing belt, water pump and other parts may go up. What level of shop is doing the work, dealership or lube and tune place? How experienced is the mechanic on doing this work on a PT? What brand/quality of parts will be used?
Tags
2006, motor mounts, parts and labor cost, repairs
2006 Pt Cruiser Misc Parts chiefsfanforever70 Classifieds: For Sale/Trade 2 01 Feb 2015 09:51 am
Parts compatible years - 2003 parts on a 2006? Wutliss420 Tech & Performance Forum 1 22 Feb 2013 03:25 pm
estimate for labor to install bushings on 5speed GT BrianW General PT Cruiser Discussions 1 17 Jul 2010 02:02 pm
2006 pt cruiser parts rte662006 Classifieds: For Sale/Trade 0 17 Apr 2007 04:15 pm
