P0508 and revving to 3k at startup
Old 29 Jun 2016, 09:12 pm
Default P0508 and revving to 3k at startup
I've been having all sorts of new fun issues with my 2005 PT. I got a reman PCM and I'm experiencing some new behavior I've not seen before. Besides the P0508 code, when I start the car up (even when warm), it revs to about 2900 RPM before settling down to ~1k RPM idle. It never did that with my old PCM! Very weird. My IAC valve is fairly new, I have new seals on the intake manifold (both at the head and between the lower and upper manifold pieces), I can't find any obvious leaks from spraying water around intake air components, it's getting rather confusing.
Any experience with this is greatly appreciated!
Old 30 Jun 2016, 06:29 am
Default Re: P0508 and revving to 3k at startup
Where di you get your PCM from? I got 3 or 4 from the same company before one actually worked (but only for 10 months)
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Jun 2016, 12:40 pm
What problems were you having with the original PCM?
Old 30 Jun 2016, 02:28 pm
Fk5 Fk5 is offline
FWIW, 3k is where my car revs up to when it has a massive (ahem) vacuum leak. It will then settle down to 1200-1400. Double check all your vacuum lines and the lines to the booster. Pull the one on top of the throttle body off and it will behave much like that.
2003 GT 5 speed
162,000 miles
Old 02 Jul 2016, 10:27 pm
The speedometer stopped working. I checked the wire harness for continuity and replaced the trans output speed sensor (a cheap enough part) and still no speedometer. The new PCM fixed that problem... While introducing yet more issues.
All Computer Resources out of Florida. The first PCM they sent me was absolute garbage, came from them with numerous trans controller faults and wouldn't shift out of 3rd gear when it warmed up. They replaced that one with this one, which controls the trans a lot better, but now I have this weird issue.
And I'm on the same page, absolutely. The really weird thing is that I've gone over the vacuum lines pretty finely and can't see any issues. I've put a hand vacuum pump on each of the 3 vacuum hookups on the intake and they all seem to hold a 20-25 psi vacuum. It's kinda boggling my mind.
Worse yet, I was pulling into a parking space at a hardware store today and just as I was getting ready to stop and put it into park, the car revved with any accelerator pedal input and scared the everloving piss outta me. Had to jam on the brakes to make it stop. Are there any non-obvious places for vacuum to leak?
Old 02 Jul 2016, 10:46 pm
HippysChick's Avatar
Did you check your PCV valve? (I think that's the name of it.)
Our 07 PTC had a sticking valve - that may actually have been one genuine error that wasn't related to the Saga of the TIPM.
https://www.facebook.com/photo.php?fbid=10151892189824122&l=627caad7f3
Previous PT Cruiser: 2007 Touring Edition (non-Turbo) in Ocean Pearl.
Current Cruiser: 2007 Limited Edition Turbo, chrome trim package, Cool Vanilla (husband's car).
Now driving a 2014 Ford Escape SE 2.0 Ecoboost, Deep Impact blue (perhaps not the best name choice for a vehicle of mine!)
Old 03 Jul 2016, 12:17 pm
I'll pull it out and check it, but I replaced it not but maybe 3 or 4 months ago.
Old 03 Jul 2016, 12:30 pm
If you didn't have that high rev issue before , you should'n have with the new PCM. I got a bad one from them too, they refunded my money.
73 Charger SE
01 Sebring flip
Old 03 Jul 2016, 12:37 pm
When did you replace the original PCM with the reman PCM?
Do you still have the original PCM?
Tags
p0508
P0508 / P0579 - codes won't go away MrSpkr Tech & Performance Forum 1 02 Nov 2015 01:57 pm
p0420 p0508 cocacola144 Tech & Performance Forum 25 09 Apr 2012 07:35 pm
No idle and codes P2074 and P0508 Cat22 Tech & Performance Forum 2 19 Oct 2011 05:57 pm
'04 limited turbo throws code p0522 and p0508 Blugirl Tech & Performance Forum 5 06 Dec 2010 04:24 am
Revving Problem? GuyOwen Tech & Performance Forum 2 17 Nov 2001 11:58 pm
