rough idle no codes
Old 30 Jun 2016, 05:08 pm
Default rough idle no codes
my 2003 pt was driving when started running rough and check engine came on..showed code for air intake air sensor changed no change but light went out but no codes..changed plugs and wires..no change but new codes for cam shaft sensor changed cam and crankshaft sensor with no change..still rough idle and no codes..could this be the map sensor??anybody have any ideas??
Old 30 Jun 2016, 05:27 pm
Default Re: rough idle no codes
WELCOME TO THE FORUM
You might make a little effort to search the forum for some answers to your questions. There is lots of same information available!!!!!!
Also as a new member a couple things to think about?
PT problems read this FIRST
and more importantly ...
WELCOME and Forum Rules
We encourage all new members to say hello and introduce yourself to the rest of the community by starting a post in the Welcome New PT Owners thread at the top half of the forum.
- Try the Search feature. It's not perfect, but so many topics have been discussed repeatedly that chances are you'll find some great info in old posts.
- Try the FAQ page for common questions like 'Posting a Picture', signatures, etc.
Old 30 Jun 2016, 05:29 pm
First check to see if your battery terminals are clean (spotless).
How may miles on your NON Turbo ? Pt Cruiser?
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Jun 2016, 08:36 pm
Welcome to the forum.
I would suggest first checking your fuel pressure. You should be getting 58 +/- 5 PSI.
Old 01 Jul 2016, 02:02 am
_PTGT03's Avatar
a rough idle is normal on the GT models. could be also engine mounts...
Old 01 Jul 2016, 06:03 am
While you're throwing parts at it, you might as well change the coolant temp sensor. I have a GT and it idles rough. I've tried all kinds of things and nothing has ever resolved it. It still runs like a bat out of hell and gets 22-25 mpg.
Old 01 Jul 2016, 11:32 am
Also how are you checking for engine trouble codes?
Old 06 Jul 2016, 11:18 am
My rough idle is because of motor mounts. I'm not feeling any vibrations or roughness at any other time.
Question: At what point is it dangerous to not have them replaced, which is expensive? Or is it not dangerous at all?
It's a 2007 Convertible with about 113 thou miles on it.
Old 06 Jul 2016, 03:52 pm
Driving on worn or fractured upper and lower struts (engine supports) will cause failure to the lower engine mount which is very labor intensive to replace. $$$
rsrocket1 likes this.
Old 06 Jul 2016, 04:08 pm
rsrocket1's Avatar
As NitroPT said, it can lead to expensive repairs. If the torque struts are all that need replacing, they are about $10-$12 mail order or $30 is each at a local parts store and take maybe 1/2 to 1 hour to replace and align. Lots of Youtube videos will show you how to replace them but make sure you get the spacing set correctly once they are in and before you torque down the bolts.
Rough Idle-Replacing the IAC Idle Air Controller engineerrock Tech & Performance Forum 9 07 Jun 2014 07:24 pm
error codes, hesitation, and rough idle Kevkish10 Tech & Performance Forum 8 10 Oct 2013 08:21 am
'07 PT - Rough Idle, rough acceleration, and shuts off if it idles for too long La_Bruja Tech & Performance Forum 3 09 Aug 2013 07:50 am
Rough Idle And No Codes scatgo Tech & Performance Forum 6 07 Jul 2009 09:00 pm
Rough Idle, Rough @60, check engine light NEW Dystroy Tech & Performance Forum 8 12 Jan 2009 09:07 pm
