no crank problem
  • 1 Post By sanatanadharma
Old 01 Jul 2016, 01:37 pm
Default no crank problem
here is what happened driving in a bad rain storm and my 2004 pt stopped running pulled over tried to restart turned the key nothing I have dash lights locks windowes had it towed home I have checked the starter power on it but not on post with key engaged changed the starter relay and tried to check for codes but no power on the plug could it be the computer if so how do u check it are they a main fuse that supplies the computer any help is greatly appreciated.
Old 01 Jul 2016, 04:05 pm
Default Re: no crank problem
Welcome to the forum. If you have a moment you can introduce yourself to the forum and post some information about your PT Cruiser.
I would suggest you check fuse #13 ASD (20amp). You might have a short somewhere caused by the rain and it blew the fuse.
Is your security red little light on on the dash?
Have you verified there is no voltage going to the solenoid from the ignition switch? Sometimes the ignition actuator goes bad.
If the ASD fuse is good and there is no security light on I would suggest checking the ground wires going to the inside drivers side fender. Sometimes the group of ground wires corrode and lose contact.
Old 01 Jul 2016, 04:24 pm
I believe the ground for the starter is bolted to transmission / engine.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 01 Jul 2016, 10:16 pm
Because Trump
No Crank clindley Welcome New PT Cruiser Members 2 09 Jun 2015 09:46 pm
Another Crank Pulley Problem Patrickbruce Tech & Performance Forum 1 21 Dec 2014 08:04 pm
@002 will crank but will not run jrywb329 General PT Cruiser Discussions 0 01 Jun 2014 10:47 am
Strangest No crank problem yet Phinzor General PT Cruiser Discussions 18 21 Mar 2014 11:39 am
Won't crank sometimes! RodF763 Tech & Performance Forum 8 09 Sep 2010 12:31 pm
