01 PT Overheats with AC on
Old 04 Jul 2016, 12:27 pm
Default 02 PT Overheats with AC on
Had a new fan, both low & high speeds work...AC is blowing cold air......radiator has been flushed, no gurgling or bubbling.......temp gauge goes above the halfway mark after some time driving and keeps going up unless I shut down the AC & let the fans cool down the engine.......only thing I noticed is that I don't hear the AC & fan cycle as it usually does before.....really had not much clue.....
Old 04 Jul 2016, 12:33 pm
Default Re: 01 PT Overheats with AC on
Did you check the coolant level by taking the radiator cap off?
Did you try burping the radiator to make sure there is no air in the coolant system?
Does it overheat at both high and low speeds or just low speeds?
Old 04 Jul 2016, 01:13 pm
Did you check the coolant level by taking the radiator cap off? yup, radiator coolant level was fine, even replaced the cap recently.
Did you try burping the radiator to make sure there is no air in the coolant system?yup, burped the rad as well through the nipple near the thermostat....upper hose gets hot too.
Does it overheat at both high and low speeds or just low speeds?both speeds especially when stopped/stationary
Old 04 Jul 2016, 01:26 pm
If it overheats at high and low speeds I would suggest checking your thermostat. When the engine overheats the thermostat can change making it not working properly. The thermostat might not be opening up all the way.
Old 04 Jul 2016, 02:49 pm
If its not the thermostat recheck the that the fan is running and cycling as the temperature gets to half way on the gauge.
It may run sometimes if the harness connector is heat damaged.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 04 Jul 2016, 03:17 pm
Radiator fan has no effect on engine temperature at high speeds. This PT Cruiser overheats at high speeds.
Does it still overheat without the A/C running at low or high speeds.
Old 04 Jul 2016, 04:33 pm
You MIGHT want to do a flush and fill. Maybe the radiator or heater core is getting clogged.
Old 04 Jul 2016, 11:30 pm
thermostat & water pump were replaced late last year during the t-belt replacement.
Old 04 Jul 2016, 11:32 pm
fan just kept running on high speed and AC doesn't cycle on & off.
It doesn't overheat at high speeds, only when you're stopped.
overheats at random! help jonathan_mckenzie05 Tech & Performance Forum 10 09 Oct 2014 05:58 am
03 turbo overheats and no ac harley55 General Turbo Discussions 2 19 Nov 2013 08:06 pm
Car Still Overheats VroomMaster Tech & Performance Forum 36 30 Aug 2011 10:51 am
When AC is on PT overheats. Also looking for PT mechanic in NYC Marcos Northeast PT Forum 5 02 Jul 2011 06:29 pm
05 PT overheats when idle sponge9012 Tech & Performance Forum 26 04 Feb 2009 01:33 pm
