CEL
Old 06 Jul 2016, 04:45 pm
Question CEL
Hi Everyone,
As I was driving there was a flashing CEL. Then I stopped for a few minutes. Then drove now it's solid orange. I tried the key trick no code .
Any ideas? Should I disconnect the battery?
Thank you for you're help
2006 PT touring edition, 5 spd manual, 140K, MSD 8.5 mm wires, Champion plugs
Old 06 Jul 2016, 04:57 pm
Default Re: CEL
I would suggest taking it to an auto parts store where they can put their OBDII Scan Tool on it and tell you what the codes are for free.
Old 06 Jul 2016, 05:01 pm
Default Re: CEL
In CA they stopped doing that. I might just buy and OBD tool..
Old 06 Jul 2016, 05:17 pm
cruserdad1976's Avatar
Default Re: CEL
Harbor Freight is your freind
Old 06 Jul 2016, 05:22 pm
Default Re: CEL
They are reasonable at harbor freight
Search results for: 'obdII Scan tool'
Old 06 Jul 2016, 07:15 pm
Default Re: CEL
I bought an OBDII at Harbor Frueght. Misfire on cyclinder 4. I'm assuming done new wires and plugs should solve this.
Old 06 Jul 2016, 08:08 pm
Default Re: CEL
When was the last time the spark plugs and spark plugs were replaced?
Old 06 Jul 2016, 08:47 pm
Default Re: CEL
Approximately 45k miles ago plugs only . Wires approximately 70k ago MSD 8.5 mm
Thank you
Old 06 Jul 2016, 08:52 pm
rckstein's Avatar
Default Re: CEL
Thank you
New plugs are recommended every 30,000 miles, new wires every 60,000 miles. Has your PT had the timing belt replacement done?
Old 06 Jul 2016, 09:09 pm
Default Re: CEL
Yes, timing belt, water pump, thermostat and new drive belts.
They replaced all lifters and rockers, new spark plug housings as wee at 70k before the extended warranty ended...not to mention a new manual tranny
