06 pt issue
Old 09 Jul 2016, 03:21 pm
Default 06 pt issue
hey all i have a non turbo base model 06 pt it has low compression in cylinder 2 causing a misfire but i was wondering if at alll if a bad ac/compressor could case the low compression issue? any help on the matter would be greatly appreciated
Old 09 Jul 2016, 03:39 pm
Default Re: 06 pt issue
Have you checked spark plugs and wires?
What is the engine compression for all 4 cylinders?
Did the engine overheat?
What engine trouble codes are you getting? and are you using an OBDII Scan Tool?
Was there any work done before the misfire code came up?
Old 09 Jul 2016, 03:55 pm
cylinders 1,3,4 are all 150 psi+ cylinder 2 is 60 no its never over heated since I've had it i put new injectors plugs wires and coil pack also is a straight pipe so no catalytic converter issue
rckstein's Avatar
Welcome to the forum
How many mIles are on it? Are you the original owner where you know the service history? Has the timing belt work been done?
Old 09 Jul 2016, 04:05 pm
second owner used to be a taxi before it was repo'd 180k miles timing belt still factory
Old 09 Jul 2016, 04:07 pm
rckstein's Avatar
It's had a rough life then, and way overdue for timing belt replacement.
Old 09 Jul 2016, 04:13 pm
yes but i dont think a timing belt would cause the low pressure in 2nd cylinder
Old 09 Jul 2016, 04:36 pm
Have you done both wet and dry compression test on cylinder 2?
I would also suggest doing a cylinder compression leak down test to see where the leaking is coming from.
Old 09 Jul 2016, 05:48 pm
i only have tool to do dry test i think the pressure gauge
Old 09 Jul 2016, 06:14 pm
For the wet test the only difference is you put 4 squirts of engine oil in the cylinder and do the same as you do for the dry test.
A/C Issue geeminator Tech & Performance Forum 1 21 May 2016 01:34 pm
A/C issue rgcruiser Tech & Performance Forum 1 23 Jul 2014 04:00 pm
A/C Issue alanrw Tech & Performance Forum 7 11 Oct 2013 11:45 pm
possible a/c issue PuterChickFL Tech & Performance Forum 1 08 Jul 2013 01:18 am
AC Issue - Help if possible falconut Tech & Performance Forum 13 19 Aug 2011 12:40 pm
